Advantages/Disadvantages strut tower braces 1PC vs take-apart
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
Re: Advantages/Disadvantages strut tower braces 1PC vs take-apart
One is rigid and the other has hinges that allow freedom of movement in one of the most important directions you want to constrain. The fixed bar is fully constrained and makes the chassis assembly more rigid. It's like having a box top with hinges vs. a rigid structure.
The joints are added to allow length adjustment to fit different vehicles (not for easy removal). But I'm pretty sure you would think it's silly to attach subframe connectors with spherical joints. Same applies here, just a different chassis stiffening component.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
The rubber in the OE replacements will deflect, the after market ones, with a stainless steel spherical bearing, won't. Checkout the Founders mount for example:
https://www.foundersperformance.com/...v=7516fd43adaa
JamesC
JamesC
Wow. Those look really sturdy. I'm not going to race my car though. It's a vert and I want to stiffen up the chassis as much as possible. I already have the Spohn SFCs which did a great job.
L98IROCZ89
04-05-2002 02:37 PM
86TpiTransAm
06-01-2001 05:22 PM
Smasher
11-11-2000 07:04 PM
