Advantages and disadvantages have pulling motor...
Old Apr 4, 2002 | 01:28 AM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
What are the advantages of having the motorized trunk pull down vs. the non motorized, standard latch?
I think I may have to convert mine to a standard latch... am I losing anything other than a cool little device that is probably gonna break again? Will the trunk stilll close flush and even with teh body? Is the back hatch glass any more likely to break? Any info on this is appreciated.
Old Apr 4, 2002 | 01:59 AM
Guest
Guest
Posts: n/a
Re: Advantages and disadvantages have pulling motor...
Well, they didnt start using them until 1986. If you can find a 82-85 that has a trunk that doesnt close flush or has more of a tendency to break the glass I'd be really surprised.
Old Apr 4, 2002 | 04:25 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
You'd think the standard would close better not being controlled by a machine. All I know is when the motor breaks and you have a hatch that won't close its 1 of the most annoying things.
Old Apr 4, 2002 | 06:38 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i've "converted" on all my roc's from the electric POS pull down motor. i've experinced no ill effects. the best mod i've ever done.
Old Apr 4, 2002 | 06:53 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I understand it was designed that way to aleviate an air pressure problem inside the car. The one on my 89RS convt has 210,000 miles and still works. Of course the trunk is much lighter and I have owned the car since 38K and don't slam the trunk.
Just call it a weight saving mod.
Old Apr 4, 2002 | 07:04 AM
Car: 1988 IROC-Z
hehe
Old Apr 4, 2002 | 12:10 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Madmax... Actually I see all too many 82-86 base model camaros where the trunk does not close flush with the bumper... it will be all uneven and higher on one side... that is my concern. I'm trying to maintain a nice car, not throw together a pile of junk.
I think I am going to convert to standard latch then. I would love to get another used motor, but if it breaks again it will only cost me more money. Thank you all for your input... I originally was very skeptical about converting, but you guys make me feel better about it.
Old Apr 4, 2002 | 01:32 PM
Guest
Guest
Posts: n/a
Its probably age or damage related, its not pull down related. I've owned 2 without and they had no alignment problems.
Old Apr 4, 2002 | 03:01 PM
82camaro's Avatar
Car: 82 camaro SC
Higher on one side than the other is probably a tweaked hatch. The standard latch ones work just fine. Mine's worked since 82. When I installed the spoiler I adjusted it slightly so it was perfectly flush--that was 5+ years ago. I haven't experience any air pressure related problems
Old Apr 5, 2002 | 09:02 AM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
POS?? I've owned 2 Camaros with the pull down latch and driven them a total of 280,000 miles over 14 years and never had any problem with either of them.
Old Apr 5, 2002 | 02:25 PM
Car: 1988 IROC-Z
well when you have a system back there (pair of 12"'s) believe me that thing is a pos. to be more exact the fragile plastic gear housing is the pos. as well as the plastic guides the latch slides up and down on. the motors are a ok . will all that bass the little plastic things crack and break within a couple of weeks. sorry for the confusion.
Old Apr 5, 2002 | 02:37 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
If it won't close flush maybe the catch is not aligned properly or check the rubber bump stops they are adjustable
wigmobile
Feb 26, 2025 02:56 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
sylentnite
Sep 9, 2015 02:55 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
luvofjah
Sep 3, 2015 07:08 PM
