Steering Column Rebuild Kit
Old Dec 26, 2019 | 06:20 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
My steering wheel/column has been super loose, so I pulled the column to rebuild it. Do they make a rebuild kit with new bearings?
From what I can tell, there are two bearings at the top of the column held in with rubber guides and races. There is a bigger bearing at the bottom of the column. Am I missing anything? Is there anything else that should be replaced in a steering column rebuild? Where can I get parts? The auto parts stores only have the lower bearing, but no upper bearing.
I’ve attached a pic.
Old Dec 26, 2019 | 08:00 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Steering Column Rebuild Kit
https://www.ebay.com/itm/1972-2002-C...UAAOSw6VNbGpgG
Old Dec 27, 2019 | 03:24 PM
85cmroz28's Avatar
Engine: L69
Thank you - ordered today.
Old Apr 9, 2025 | 04:30 AM
Ghostpepper415's Avatar
Car: 1992 camaro z28
Engine: Factory 5.7
Did replacing those two bearings fix the play or if it made the steering more tight
Old Apr 9, 2025 | 09:42 AM
Beeman's Avatar
Be sure to use loctite on the 4 torx headed bolts in the upper support for the tilt,
Old Apr 9, 2025 | 11:45 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Is this all there is to rebuilding the steering column, 2 bearings? What about the box, does that also introduce play?
Old Apr 9, 2025 | 12:28 PM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
this is a 6 year old thread, but still helpful today.
replacing bearings wont make the steering more tight, but it will reduce side to side slop in the steering wheel.
Yes use loctite on the torx bolts. We use the steering wheel as a handle getting in and out, and that puts alot of stress on the column
And also yes, the column rebuild is pretty easily done if you have all the parts and the time to do it. And of course the box induces play, as well as worn steering components like tie rod ends..
-get a rebuilt box here for $199 https://www.classicindustries.com/shop/search/?q=p18511
Old Apr 9, 2025 | 12:58 PM
LiquidBlue's Avatar
Transmission: MD8
Are you saying any slop in the steering column, including steering box is not the same as say a bad tie-rod. just trying to learn about this. if the steering column or steering box have play, will the wheel turn, but not engage the steering linkage as it should, you might turn it an extra 1/4" before it would normally engage the steering linkage. this is what I mean by play/slop ?
Old Apr 10, 2025 | 12:55 PM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
everyone uses these terms loosely.
i was refeering to the steering wheel and colum only.
if you can turn your steering wheel and the tires/suspension isnt moving, then yes, you have some worn parts. this could be called, loose, sloppy, slop etc.
i was referring to grabbing the steering wheel, not turning it, but physically moving it around. This is caused by loose or broken parts, bad bearings, etc.
So yes, simliar, but different.
-everything from the steering wheel to the balljoints should be serviced, and nice and tight to prevent any loosness throughout the entire steering and suspension system..
Wadebryant
Sep 27, 2007 07:46 AM
Cambridge205
May 27, 2007 04:32 PM
