Truck 5.3 p steering lines in 3rd gen
Old Apr 30, 2020 | 09:13 PM
86iroc504's Avatar
Car: 86 Camaro
Engine: '03 4.8 vortec
Transmission: 4l60e
Does anyone have any pictures and/or part numbers for adapting power steering lines into the third gen gear box? I have the pressure line but no return line and I need to know which goes where
Old May 2, 2020 | 12:02 AM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: Truck 5.3 p steering lines in 3rd gen
I just got some power steering to AN conversion fittings and made my own pressure line from hydraulic braided hose and I have mine Going from the 5.3 PS Pump to the hydro boost and back to the box. Return mine I used the stock PS return cooler line below the rad and used a AN hard tube tee adapter and branched the return back to the pump and the return from the hydro boost. My 5.3 pump has the hose barb coming out the side toward the front of the motor. You can use regular PS rubber return line or 250psi push lock hose, I think return pressure are <60psi.
LT1IROC-Z
Dec 3, 2013 08:03 PM
Realmac4
May 9, 2011 02:46 PM
bigchief
Aug 7, 2010 10:16 AM
lovemyv8
Fabrication
Jun 29, 2007 12:32 AM
fattdaddy
May 9, 2005 10:30 PM
