Front Wheel Bearings
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Are Timken brand wheel bearings still the preferred brand of wheel bearings? Are there any other brands that are considered high quality? Planning on a complete front end tear down and rebuild and that's an area that I'm ok with spending a little more on if the quality is there.
Re: Front Wheel Bearings
They're most all about the same, except for the cheeeeeeeeep offshore knockoffs. Pay more attention to country of origin and less to brand name on the box. Look for US, Japan, Germany, Canada; avoid India, Thailand, Malaysia, China, etc.
Engine: 5.7 HSR
They're fine. Assuming of course, no Thailand, Myanmar, Kazakhstan, Cambodia, etc. as COO.
Grease em every 20 or 25k miles, or every brake pad change. That also matters more than the name on the box.
Car: 85 Iron Duke, 88 GTA and 92 TA
I installed Timken in april... and was a bit offended by the outer bearing having a plastic cage...
The inner was all metal... I had national bearings before and they were all metal. But I installed the Timken anyway, so far, so good. Works. Wheel bearings are cheap and you can swap them in a few minutes, so I decided not to avoid the plastic and live with it.
The inner was all metal... I had national bearings before and they were all metal. But I installed the Timken anyway, so far, so good. Works. Wheel bearings are cheap and you can swap them in a few minutes, so I decided not to avoid the plastic and live with it. Member
Car: 1989 IROC
Engine: 5.7 TPI
Axle/Gears: 2.77 Posi
Engine: 5.7 HSR
Car: 1989 IROC
Engine: 5.7 TPI
