Fixed: Brakes don't work good anymore
Old Jan 15, 2002 | 04:52 PM
Spifz's Avatar
Car: 1986 Z28 / 2012 CLS550
Engine: F-1R -> Aluminum block 540
Transmission: T56 Magnum + GForce gears
Axle/Gears: Ford 9" 3.00's + Eaton Truetrac
It felt like loss of power assist, but when I would pull the check valve off the boost cylinder, it would swoosh, like it had good vacuum 'stored' Twasn't until today that I realized when I switched the valve cover sides, to get the oil fill out in the open, I don't have anything plugging the PCV on the drivers side... Carb vac. line goes in the pass. side, and 1/2 vacuum leak on the other side ... That's another place to look for leaks if anyone was making a list.
1992rs/ss
Jan 31, 2025 05:10 PM
Terrell351
Jun 13, 2021 01:13 PM
Reddeath210
Oct 6, 2015 08:20 AM
dhonda200
Aug 11, 2015 11:50 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
