Adjustable torque arm and crossmember
Old Dec 10, 2020 | 09:15 PM
Magik's Avatar
Car: 91 camaro rs
Engine: 350 Police tbi
Axle/Gears: 12 bolt 373 posi
Hi all new to to the forum. Not new to 3rd generations had a few of them when I was younger. I just purchased a 91 rs with a "police " swaped 350 tbi ,700r4, and 373 posi, b&m ratchet shifter,and adjustable torque arm and cross member with integrated driveshaft loop.
The problem I'm having is that after changing the busted transmission mount to a energy suspension unit ,the drive shaft hits the loop when decelerating. I have no idea why it started doing this after I changed the trans mount?
Anyone have any ideas?
Old Dec 11, 2020 | 06:13 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Re: Adjustable torque arm and crossmember
if you installed the metal spacer when installing the bushing there is your problem. Remove the metal spacer and it will probably clear.
Old Dec 11, 2020 | 01:20 PM
Or, if you didn't install it before, try installing it now. You either need to raise the trans with respect to the crossmember, or you need to lower it; do whatever spacement accomplishes the thing you need.
Old Dec 11, 2020 | 02:42 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Who's torque arm and crossmember are you using, even without the plate it shouldnt come close to hitting
Old Dec 11, 2020 | 03:10 PM
Magik's Avatar
Car: 91 camaro rs
I did install the metal plate that came with the energy suspension trans mount. The torque arm and cross member were on the car when I got it so I don't know what brand it is. It looks like a sophn unit. I will try removing the plate to see if that helps. It looks like it wouldn't raise the tali end of the tranny that much but ill try it.
Old Dec 11, 2020 | 10:57 PM
Magik's Avatar
Car: 91 camaro rs
its from sophn just researched it.
Old Dec 14, 2020 | 08:31 PM
Magik's Avatar
Car: 91 camaro rs
SOLVED!!! Previous owner used wrong bolts to fasten the torque arm to the diff. For one the bolts are too skinny ,and secondly they are way too short. The nuts are barley on the the threads. The diff is jumping up and down under acceleration and deceleration and braking. I ordered the longer umi bolts.
Old Dec 15, 2020 | 06:54 AM
Simple is good.
Old Dec 15, 2020 | 07:29 AM
Abubaca's Avatar
I'd get a angle finder and check your angles too. Never know where the last guy had it set.
Old Dec 15, 2020 | 01:29 PM
Magik's Avatar
Car: 91 camaro rs
Yes for sure!
Cheerio
Dec 15, 2020 09:18 PM
Drone358
Fabrication
Sep 27, 2016 09:51 AM
RunawayRadio
Aug 16, 2016 08:31 PM
91 1LE
Nov 21, 2012 01:23 AM
zupmanZ28
May 7, 2004 09:46 PM
