Top shock nut
Old Mar 13, 2021 | 06:12 PM
88BLKTransAmGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 3.77
Top shock nut
Trying to install lowering springs on the front of my 88 gta. Of course top nut on the front shocks will not budge. I have used penetrating oil and a blow torch. I have pretty much stripped the hex out of it as well. Do I need to just cut the nut at this point and buy a replacement nut? Does anyone know the size to replace it? Or do I need a new shocks
Old Mar 13, 2021 | 06:13 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Top shock nut
Have you hit it with an impact wrench?
My backhold hex is stripped too. I hold the shaft with a vice grip plier from the underside (as high as I can so it's not an important area for sealing).
Old Mar 13, 2021 | 06:21 PM
Engine: 5.7 L98
Axle/Gears: 3.77
Re: Top shock nut
I hit with my impact trying to let the hammer jar it loose but I didn't hold it on the underside. I will definitely try that next.
eddie jr
Mar 22, 2006 09:33 PM
KC10Chief
Jul 15, 2003 11:13 PM
88greyiroc
Jan 3, 2002 11:29 PM
Xenodrgn
Nov 24, 2001 07:50 PM
KNTRDR
Oct 19, 2000 08:29 PM
