Idler arm replacement without the original
Old Apr 14, 2021 | 08:20 PM
11B's Avatar
11B
Car: IROC-Z Z28
Engine: 5.7L TPI
Transmission: AT
Axle/Gears: 2:73
My question is how do I replace the idler arm without one in place or from the moog version to the a.c. Delco.As many of you know or will know, the moog idler arm is the wrong part for our cars. I picked up an a.c. Delco according to the part number from the forum post which discusses this topic at length.
Old Apr 14, 2021 | 08:40 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Idler arm replacement without the original
Skip step one.
1. Remove old idler arm.
2. Install new idler arm.
Old Apr 14, 2021 | 08:52 PM
11B's Avatar
11B
Car: IROC-Z Z28
Engine: 5.7L TPI
Transmission: AT
Axle/Gears: 2:73
Originally Posted by QwkTrip
Skip step one.
isn't the new one supposed to match the originals angle ? Thank you.
Old Apr 14, 2021 | 09:23 PM
DaveyDug's Avatar
Car: 1989 IROC
Engine: 5.7 TPI
Axle/Gears: 2.77 Posi
Look through the slot in the frame for the marks that show where the old idler arm bolts were located. Install the new arm so the bolts end up in the same location.
Old Apr 15, 2021 | 07:25 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
the idler arm should keep the center link level with the frame.
the opposite end of the center link is attached to the pitman arm, which is not adjustable. Adjust the height of the new idler arm to match the height of the pitman arm-in relation to the frame of the car. you can measure off common points of the k-member. pretty simple really.
Old Apr 15, 2021 | 08:15 PM
Saxondale's Avatar
Car: 84 Z
There was a theory historically that the different casting shapes resulted in different function. But side by side the factory original and your [previously reported] incorrect version have the same drop and sweep. They are the same in function.
bikmop13
Jul 7, 2019 12:10 PM
Evilokc
Dec 11, 2018 08:55 PM
Out-Cast
Jun 28, 2016 08:54 AM
tvc 15
Aug 21, 2012 05:10 PM
TA-Rocks
Sep 27, 2010 07:55 PM
