Any more tunnel mounted torque arms?
Old Jul 7, 2021 | 03:39 PM
diablizzard's Avatar
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
I finally have the time and the money to move my project forward. The priority now is to finish with the suspension. I have the front lower control arms and the torque arm on the list. I've had my eyes on the tunnel mounted torque arms, similar to Steinjager and Alston, but they appear to be discontinued. I need to have it up that way to clear my headers. I'm running the Stainless Works longtubes with 2.5" collectors and y-pipe. Does anybody have any leads on anybody who still makes them? I prefer to have an adjustable one.
Old Jul 7, 2021 | 08:21 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
Re: Any more tunnel mounted torque arms?
S&W Racecars makes one.
Old Jul 7, 2021 | 09:25 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Midwest Chassis and Brute Speed both make variants.
Old Jul 7, 2021 | 11:16 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Here's a starting point to begin your search, https://www.thirdgen.org/forums/ltx-...s-3rd-gen.html
Old Jul 8, 2021 | 09:06 AM
Car: 86 Camaro Z28
Thank you for the info, everybody. Qwktrip, that is an awesome thread to start from. I want to avoid welding a bar across the chassis. I imagine it will severely impact any disassembly in the future.
I like the Unbalanced Engineering design a lot. I found that ws6transam did the retrofit years ago. https://www.thirdgen.org/forums/susp...decoupled.html The pictures are gone from this thread, but I found one on another forum by him. I'll send him a message to see if I can get some better insight.
The other combination I am thinking of is Hooker Blackheart crossmember paired with Founder's Performance torque arm. The big question I have is, does it clear my y-pipe? I'll need to do some more searching to find some installed images.
Old Jul 8, 2021 | 09:40 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
This is the exact set-up that I currently have. Although my exhaust is not in place yet. I will try and grab some photos but this set-up shouldn't look any different than any other torque arm setup.
Old Jul 8, 2021 | 09:49 AM
Car: 86 Camaro Z28
Awesome, I appreciate it. To clear my exhaust, I'm presently using the Hawk's T-56 crossmember. https://www.hawksmotorsports.com/84-...n-crossmember/
Old Jul 21, 2021 | 12:27 PM
Car: 86 Camaro Z28
I emailed unbalanced engineering about their torque arm. They only do a production run when there are 5 or more confirmed buyers. So, I either would have to wait or find a used piece of that's the route I go.
Old Jul 26, 2021 | 05:30 AM
clubber's Avatar
Car: '92 RS
Engine: 5.0TBI
Transmission: TKX
I'd join you if we can scare up three more. My suspension is done other than this.
Old Jul 28, 2021 | 01:22 PM
Car: 86 Camaro Z28
I'm sending you a PM
Old Aug 4, 2021 | 11:13 AM
Car: 86 Camaro Z28
I finally made my decision. I'm going to go with the welded in version of the UE TA. From looking at the images, front piece is bolted through the tunnel to a plate on the other side. The plate is then welded to a roll bar/cage. I'll be able to work with that. Also, it appears to have better ground clearance than the bolt-in version.
tyevans5
Sep 28, 2011 10:33 PM
CC89Formula
May 26, 2005 03:12 PM
spekbikes
Fabrication
Dec 2, 2004 09:16 PM
Shagwell
Apr 28, 2002 05:45 PM
Ed1LE
Aug 9, 2001 11:15 AM
