Installing ProKit Springs 87 GTA Anything Else I Need To Change Spring Related?
Car: 1987 GTA Vert & 1991 GTA 5 Speed
Engine: 87 GTA-L98 91 GTA LB9
Transmission: GTA-700R4 & GTA T5
Did a search for ProKit Springs which didnt return anything specific to my question so here I am.
Just like when changing the oil you change the oil filter. When changing the springs what items related to the springs do you change on a thirdgen?
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
Re: Installing ProKit Springs 87 GTA Anything Else I Need To Change Spring Related?
Adjustable panhard bar, Struts/shocks unless you have koni yellows already also check your end links and bump stops.
Yes have the Koni Yellows, I'll have to get a Panhard bar. Reccomendations?
Car: 92 camaro RS
Engine: LSA
UMI double poly ends $140 #2029
UMI poly/roto-joint $190 #2037
DSE with pivot bushings $273 #042108
