Panhard bar hitting gas tank 1991 Firebird
So I am installing a BMR Panhard relocation bracket due to the previous owner along all the factory parts. I have an ls1 tank installed and the Panhard bar is contacting the tank. I’ve tried readjusting the tank but no luck. Any ideas?
Car: '89 Firebird
Engine: 7.0L
Re: Panhard bar hitting gas tank 1991 Firebird
I assume you mean the upper brace bar, and not the actual panhard bar itself? I had same problem with a different brand. Founders brand will clear the 4th gen fuel tank. UMI might fit too but I have no experience with that particular piece of the UMI parnhard system.
https://www.foundersperformance.com/?v=7516fd43adaa
https://www.umiperformance.com/home/
I encourage you to post your experience in this thread so other can learn from it, https://www.thirdgen.org/forums/susp...rd-heidts.html
If you're in the middle of a build and have not wired the fuel tank yet, then this thread will be helpful too, https://www.thirdgen.org/forums/ltx-...e-4th-gen.html
