Bump Steer Kit
Old Nov 3, 2022 | 04:56 AM
83 Crossfire TA's Avatar
Bump Steer Kit
So doing a search for them, it looks like the major players for our cars are UMI, Spohn and AJE.
Are there others?
Is one any better than the others?
It looks like UMI is the most expensive and easiest to get, Spohn is in the middle (though I've had problems with Spohn parts so I'm kind fo biased here) and AJE is the cheapest by like $40.
Old Nov 3, 2022 | 08:00 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Re: Bump Steer Kit
For what it's worth these are the parts I ended up using, I decided to piece together my bump steer components.
Steel Swaged Tube 5/8 Inch Threaded, 9 Inch Length, Black (afcoracing.com)
Steel 5/8" Heavy Duty Right Hand Rod End Heavy Duty (afcoracing.com), Got lucky and found a set of brand new rod ends on eBay for cheap
Proforged 104-10058 Proforged Inner Tie Rod End (holley.com)
Safety Retaining Washer for Rod End Bearings - Pegasus Auto Racing Supplies
Seals-It WS3125 Heim Joint Rod End Seals, 5/16 Inch Hole, Set/6 (speedwaymotors.com)
Bump Steer Kit 0.1 to 0.5 in Spacers | Allstar Performance, I didn't end up using the bolts as they were too short for my application.
Old Nov 3, 2022 | 08:38 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Bump Steer Kit
I have a Baer bumpsteer kit on my GTA.
Old Nov 3, 2022 | 01:56 PM
91banditt2's Avatar
Engine: 5.7 HSR
Re: Bump Steer Kit
Are there others?
Got a link to the AJE bump steer kit, only thing i'm finding is for mustangs.
Old Nov 3, 2022 | 03:34 PM
Re: Bump Steer Kit
https://ajesuspension.com/product/3r...ump-steer-kit/
https://www.jegs.com/i/AJE-Suspensio...-3434/10002/-1
it concerns me that it looks different than the rest
Old Nov 3, 2022 | 03:42 PM
91banditt2's Avatar
Engine: 5.7 HSR
Re: Bump Steer Kit
they either don’t know what they’re selling or they’re too lazy to use an actual photo of the correct bump steer kit for the 82-92 F body. They’re using the same stock photo as an SN 95 mustang
Old Nov 9, 2022 | 04:00 PM
Re: Bump Steer Kit
So no one has any advice about the bump steer kits out there?
Old Nov 9, 2022 | 08:38 PM
jayg's Avatar
Car: 1992 Formula 350
Re: Bump Steer Kit
I hope their products are better than the web design. This looks interesting.
https://ajesuspension.com/product/82...nd-pinion-kit/
Old Nov 9, 2022 | 08:52 PM
jayg's Avatar
Re: Bump Steer Kit
Old Nov 9, 2022 | 08:58 PM
jayg's Avatar
Re: Bump Steer Kit
I have the Spohn kit. Not sure what this guy is using. Car has been on jack stands since before Covid so can't comment but this video makes me wonder if it's beefy enough.
Old Nov 10, 2022 | 11:14 AM
91banditt2's Avatar
Engine: 5.7 HSR
Re: Bump Steer Kit
I think he may be running the UMI kit
Old Nov 11, 2022 | 02:35 PM
corner_inc's Avatar
Re: Bump Steer Kit
The UMI kits look like they come with a heavy duty version with a bolt. I'd probably trust that more than the stud. Looks like nice stuff.
Old Nov 15, 2022 | 03:40 AM
Re: Bump Steer Kit
I ended up calling UMI and asking about their 2 kits and basically got the answer that the tapered studs tend to get bent, anything that you're going to actually drive hard get the HD with the bolt. I mentioned that I was originally going to get the stud and figured if I bent the stud I can always swap some 5/8" bolts in, and he added that they come with a longer shim pack and you'll probably pay $10-15 each for that size 5/8" bolt, each.
I have the HD kit coming.
Old Nov 23, 2022 | 09:07 PM
McLovin1181's Avatar
Re: Bump Steer Kit
I used the UMI bump steer kit in my video above.
raced 2 seasons and probably 350+ Autocross laps with sticky 295 & 315 200tw tires.
The 5/8in bolt held up fineThe UMI cheap rod end was making a lot of noise even when lubricated. Although it wasn't completely worn out.
You can just replace the cheap UMI resin filled rod ends with a higher quality one from say, Founders, QA1, or go baller with Aurora.
I made a custom kit myself with a grade 9 Bolt, ARP nut, and a machined spacer from 316 stainless.
Bump at 1in compression or rebound is about 0.003in. basically non existent.
I'll be making the spacer from Titanium eventually. And ditching the UMI tie rod connector with a WoodWard Forged set.
Kevin Vandevenne
Jan 29, 2012 03:22 PM
itsMikey
Sep 9, 2011 06:50 PM
1988-305-tbi
Jul 21, 2008 11:58 AM
Holio
May 27, 2006 03:23 AM
92RSZ
Feb 28, 2003 09:53 PM
