Clunking infront
Old May 16, 2023 | 06:31 PM
Iroc588's Avatar
Car: 1986 Yellow Iroc /1987 Blue Iroc
Engine: All 5.0 LB9 TPI
Clunking infront
I’ve noticed when driving up or down inclines or backing out of my driveway slowly with the wheel turned I get a very loud clunk/banging from the front and have no clue what it could be, changed tie rods and no change, ball joints were done about 5k miles ago but that was also about 20 odd years ago, idler arm on driver side was replaced, any suggestions?
Old May 17, 2023 | 02:14 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Re: Clunking infront
I always get a chuckle when someone on the forum tries to describe a noise from their car because it reminds me of a Seinfeld episode where George hides a recorder in his briefcase.
I'd say you are going to have to get the car up off the ground and have a look under there. spins some tires, shake the tires back and forth, use a lever to see if steering and control arms, sway bars are solid and bushings are good, look for loose plastic, and generally just see if everything is where it should be.
Old May 17, 2023 | 03:18 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Look at the sway bar end links as well.
Old May 17, 2023 | 10:31 PM
Yup, sway bars in general can make some really loud awful noises, give em a THOROUGH lookover.
Bushings are more likely to cause a "clunk" than end links, though; end links sound like change in your pocket (sorry, showing my age, I remember when there was such a thing as "change") whereas bushings sound like a loud thunking kind of racket.
Old May 18, 2023 | 07:28 PM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
Another thing to check is wheel bearings being loose. Just a thought.
Iroc588
Dec 3, 2022 08:31 AM
apie2546
Nov 26, 2015 06:25 PM
customblackbird
Apr 12, 2010 09:27 PM
86LG4T56
Sep 8, 2005 08:50 PM
Idlehands
Apr 30, 2003 09:38 PM
