Strut mount deletes?
Old Jul 9, 2023 | 04:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
This is a super long shot but do anyone know of, or any vendors reading this offer, delete plates for the strut tower openings? I can make my own but I'm trying to save time.
Old Jul 23, 2023 | 05:10 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Strut mount deletes?
For the record, Spohn is setting me up with these. Solid people over there.
Old Jul 23, 2023 | 05:56 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Are you talking about plates that cover the holes cause you aren’t using caster/camber plates?? Can’t help with an answer but would like to see what you come up with. What front suspension are you running if you don’t have caster/camber plates?0
Old Jul 23, 2023 | 07:09 PM
NoEmissions84TA's Avatar
Old Jul 23, 2023 | 11:37 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44, Tru Trac, 3:73 gears
Made my own.
Old Jul 26, 2023 | 05:25 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Originally Posted by soloc4
Made my own.
I saw your thread, you did a wonderful job on the car.
Old Jul 26, 2023 | 05:27 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
I'm building a new front end with upper and lower control arms. I need the strut plates to obviously fill the holes but also as a hard point to mount the coilover and STB.
I'll post some pictures once I get more of it together.
Old Jul 26, 2023 | 12:31 PM
soloc4's Avatar
4th gen. style? I’m not sure how well the towers in these cars would hold up long term without extensive modification. In all honesty I don’t have any experience with coil-overs with the stock strut towers.
Old Jul 28, 2023 | 05:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
My lower is kinda similar to a 4th gens layout, the upper won't be as high, it's mounting basically inside the "frame" right above the k member pocket. The spindle I'm using is a fabricated version of a c7 spindle and hub.
The coilover will mount to the underside of the factory strut tower, the plates offered by Spohn with their coilover kit provide some extra beef and I'll probably end up adding some additional support inside the wheel well, just to be safe.
Old Aug 11, 2023 | 08:11 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
I'm assuming your looking for a weld in option here, If so what about designing your own plate and send it to SendCutSend.com to have them laser cut?
Old Aug 11, 2023 | 10:09 AM
battmann's Avatar
Originally Posted by 91banditt2
...send it to SendCutSend.com to have them laser cut?
bookmarking this site for future reference. thanks for sharing!
Old Aug 12, 2023 | 09:36 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
that's a good link, thanks. Im actually trying to keep the modifications in such a way that you could go back to "stock" without having to cut anything back out.
eddie jr
Oct 20, 2005 05:27 PM
PyRo9862
Sep 11, 2003 06:03 PM
Chet
Feb 4, 2003 08:36 AM
formul8!!
Dec 6, 2002 11:36 AM
86Tra/maro
Apr 25, 2002 05:06 PM
