Strut mount alignment
Old Mar 29, 2024 | 05:21 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
I had my struts and mounts replaced awhile back, and I just noticed today that they are not the same on both sides. The passenger side is centered and the driver side is pushed all the way to one side. Is this an issue? There is a pull to the right even though it's supposedly aligned properly.
And yes, those caps are glued on. He couldn't figure out how to get them into the new mounts.
Old Mar 29, 2024 | 05:34 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Strut mount alignment
You have a copy of the alignment after they were replaced?
Old Mar 29, 2024 | 05:42 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
No, it was awhile back and they never gave me a printout. They blamed the pulling on the Kumho Ecsta tires. I won't be using that alignment shop again.
The man who installed the struts, mounts, and tie rod ends has since retired and closed up shop.
Old Mar 30, 2024 | 07:14 AM
exiled350's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 427ci Gen 1 Small Block
Axle/Gears: Strange60 4.10 Eaton Truetrac
How's the wheel look, with it shoved that far you should have some negative camber which should be plainly visible. If that's proper to spec, which I believe is something ridiculous like 0.3° ±0.5° (-0.2 to 0.7), you've got a problem somewhere.
Old Mar 30, 2024 | 02:50 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Just Noticed This Car For Sale Has Similar Settings
Old Mar 30, 2024 | 03:34 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Interesting. I don't think I've ever noticed adjustable strut mounts on any other vehicle before. Seems like there should be only one way, and that's it.
Old Mar 30, 2024 | 03:35 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Nothing really stands out to me as being crooked.
Old Apr 1, 2024 | 03:53 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Sounds like you need to go to a better alignment shop. If it's pulling to one side, very likely not the tires.
Old Apr 1, 2024 | 04:20 PM
Abubaca's Avatar
On my last two Irocs, they weren't identical after alignment. Not quite as different as yours, but noticeable without having to measure. If the car is driving and steering well, not pulling and the tires aren't wearing, I wouldn't worry too much. STILL.....getting another alignment isn't overly pricey. might not be a bad idea.
Old Apr 1, 2024 | 07:43 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
yeah I have since found another place I prefer, just haven't taken the GTA there yet. It's almost time for tires anyways, since these have some signs of dry rot.
gt4373
Aug 13, 2022 10:22 PM
The MPI 'Bird
Jul 25, 2016 09:52 AM
Chevy86 IROC-Z
Jun 3, 2012 09:56 PM
racing geek
May 10, 2008 08:56 PM
rwdtech
Oct 17, 2006 07:03 PM
