problem with alignment/steering
Old Nov 11, 2024 | 05:51 PM
Sparten2068's Avatar
Car: 1987 camaro
Transmission: T5 5-speed
Hi, i have an 87 Z28...been having a problem with my steering and aligniment and steering
so the wheels turn way farther right then they do left and the caster/camber plates are adjusted all the way inward tward the engine (both sides). the uneven turning im thinking the sterring box isnt centered correctly, but, the shockes themselves also start hitting the body/swaybar on tight turnes, they are very close to the body...left side worse then the other, it binds up and is harder to move on right turn.
i started having this issue after i installed tubular K-member and A-arms both from spohn, aloso threw in new springs whitch were taller than the stock ones but the A-arms seem level when the car is on the ground
any help woud be great, thanks in advance
Old Nov 11, 2024 | 11:26 PM
McLovin1181's Avatar
Re: problem with alignment/steering
Sounds like your center link is on backwards.
The inner tie rod castle nuts should face the front of the car.
Or the K-member isn't installed or built right .
Tubular stuff can get wonky.
Old Nov 12, 2024 | 03:37 PM
Car: 1987 camaro
ok, ill check the center link...was thinking it was possible something wasnt right with tubular parts, A-arms seem ok..i have stock ones and they seem to be same dimentions
is it possible that where the A-arms mount to the k-member is too close together? i dont have a stock one to check...would it be possible to get a mesurement for that, or even just ball joint to ball joint?
Old Nov 12, 2024 | 06:25 PM
There are body shop measurements they use for check for bent frames.
Not sure if there's a balljoint to joint measurement though.
But tire rubbing,and strut hitting means something is very very wrong.
Old Nov 13, 2024 | 02:04 AM
Car: 1987 camaro
hmm, and i was hoping to eliminate as much as possible before bringing it to a shop, i dont have the book for thoes mesuerments...perhaps i can find that info though
any chance on getting just a measuerment with a tape mesure? lol..just between the A-arm mount bolts? if not, cool
thank you in advance
Old Nov 13, 2024 | 04:08 PM
Quick measurement with a tape measure.
Balljoint to balljoint centers: 51in
Center of A-arm bolts measured across the K-member: 19.5in
Not sure if that helps at all.
Old Nov 19, 2024 | 04:37 PM
Car: 1987 camaro
helps alot thank you very much!
Old Nov 20, 2024 | 03:02 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
The spohn k member and arms have been known to create all kind of problems. I've been out the game for a while and it doesn't look like they have changed the design.
NiG
Jun 20, 2016 02:46 PM
80srobot
Jun 11, 2011 12:44 PM
Hal87
Jul 6, 2010 12:31 PM
Chevycam90
Mar 19, 2009 04:11 PM
tanager11
Jan 9, 2002 08:04 PM
