LS/t56 adjustable torque arms advice?
Old Mar 21, 2025 | 09:29 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Im near complete buying all the suspension parts to swap my drivetrain from one transam to another clean shell. While doing so now is the time to upgrade the things I didnt do last time. Currently Im going to be using Umi tubular k member and A arms for ls swap, currently have hawks t56 cross member and stock torque arm, umi adjustable lca's, umi adjustable panhard bar, strange dana s60 rear for 3rdgen stock fitment, umi 1" lower springs, qa1 dbl adjustable shocks all around.
The car is going to be mainly street/strip and occasional circuit time. I know there has been alot to say about relocation the torque arm off the trans but having a ls/t56 really limits options.
Would would everyone suggest I do to upgrade the torque arm. Get a adjustable replacement, or get a tunnel mount style which apparently hangs quite low?, or the spohn crossmember with driveshaft loop and tunnel mount torque arm.
I will be running the hawks 4" exhaust also since its a turbo ls swap so its going to be tight under there.
https://www.hawksmotorsports.com/82-...mission-spohn/
https://www.hawksmotorsports.com/198...s-motorsports/
https://www.hawksmotorsports.com/82-...i-performance/
Old Mar 21, 2025 | 12:29 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: LS/t56 adjustable torque arms advice?
Your combo will require the strength of an aftermarket unit. Buying an adjustable unit will allow you to dial in the pinion angle which will be required when you lower the car and replace the rear end. I would strongly recommend the holley LS swap trans crossmember as it relocates the torque arm mount from the trans. A panhard rod lower/relocation kit will help route your exhaust over the axle.
Old Mar 21, 2025 | 06:08 PM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
I have been using the holley blackheart cross member to get the torque arm off the transmission with good success, example in thread below-
https://www.thirdgen.org/forums/ltx-...-ls3-swap.html
see post 20 for some pics
Old Mar 21, 2025 | 07:35 PM
Engine: 2005 LQ4
Axle/Gears: 3:54
Havent thought to check holley actually. Did you also use their torque arm or another brand?
I do already have a panhard relocation bar on the current car so I should be good for the larger exhaust.
Old Mar 22, 2025 | 07:33 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Holley doesn't make a torque arm for these cars. Any unit from UMI, BMR or founders will suffice.
Old Mar 22, 2025 | 01:49 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Here is a list of torque arms I know about, https://www.thirdgen.org/forums/ltx-...s-3rd-gen.html
Old Mar 22, 2025 | 05:06 PM
alan91z28's Avatar
COTM Editor
in my builds i have used BMR, UMI, and even the OEM torque arm with the holley cross member
Old Mar 23, 2025 | 09:41 PM
Engine: 2005 LQ4
Axle/Gears: 3:54
Thanks, i went with the umi bar, hard not to at this point almost everything else I got from them. Ill upgrade to the holley cross member also. I feel sorry for the shop the needs to dial all these settings in once its done lol. Should ride and handle quite well I hope for the money I put out :P
Old Mar 28, 2025 | 09:32 AM
exiled350's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 427ci Gen 1 Small Block
Axle/Gears: Strange60 4.10 Eaton Truetrac
Be mindful you'll have to notch the top of the bracket so you can slide it on to the inner set of holes. If you install it on the outer set of holes it's too far towards the driver's side and will hit the floorpan when loaded.
86CamaroDan
Mar 14, 2016 08:04 PM
Justin69
May 10, 2015 09:45 PM
Blitz
Dec 24, 2003 10:43 AM
Dex
Jan 4, 2003 02:17 PM
IRACE87
Aftermarket Product Review
Oct 29, 2000 08:11 AM
