Rear sway bar on a ford 9 inch rear
Car: 1986 iroc Camaro
Transmission: Manual TKX
Axle/Gears: 370
Hi Guys , I put a Ford 9 inch in my 86 iroc and would like to use the original sway bar .I understand I need new sway bar brackets to foot the diameter of the new housing. Does anyone know where I could find them please? Thanks
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: Rear sway bar on a ford 9 inch rear
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
I have laser cut mild steel ones that I am not using. They came with my UMI drag bar. I have the U-bolts, washers, nuts, and the brackets. Powdercoated black.
this bar
https://www.umiperformance.com/2245-...sway-bar-rear/
These are the brackets:
https://www.umiperformance.com/2244-...tallation-kit/
these brackets:
this bar
these brackets:
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
You can use heavy duty muffler clamps in a pinch
Engine: 4++,350 & 305 CIs
I used 3"? muffler clamps and a piece of square tubing to space the bar down a bit for clearance.
Edit, 30yr? old moser 9"
Yep I had to do the same with my QP 9" since it didn't come with sway bar mounts. Didn't realize I had to check that box when ordering. Thankfully it's gone and Midwest Chassis sits in the back of the car problem free
Dscott
Mar 7, 2021 11:46 PM
