proportionvalve/master cylinder
Old Jan 27, 2002 | 09:20 PM
88transam5.0's Avatar
Hi, I did the 4th gen swap and I want to know about which proportion valve do I use and which master cylinder do I use and some part numbers if possible. I used to have drum brakes and now disc all around. The brakes work but not real good. I've heard that the disc brake cars had a different master cylinder and proportion valve. I've tried getting GMPARTSDIRECT and DAL to see which valve would work but I guess they don't want to be liable. I know some out there has done this swap. Is it true from 88 to 89-92 they had different valves and master cylinders. Oh, I have an 88 transam 5.0 TPI. thanks
Old Feb 3, 2002 | 07:38 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I have 1LE brakes on all 4 wheels. I have great success using the stock J-50 (disc front-drum rear) master cyl and proportioning valve.
One member has had a rather hair raising ride in my car. Perhaps he cat attest to the brake function.
Thanx,ANDYZ28
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
