could this be a cracked frame around the steering box??
Old Feb 3, 2002 | 01:47 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
Lately the problem seems to be getting worse. When making a right turn, usually at parking lot speeds I can hear a loud pop and sometimes I can even feel it through the gas pedal. I'm thinking the frame might be cracked. I've gotten under the car and looked at the frame but didn't see any cracks. Are these cars more likely to develope the cracks behind the steering box? I plan on installing a Steering Brace hopfully by next week if GW gets them in stock. If it is a cracked frame will installing the wonder bar eliminate the pops? Below are steering components I've already replaced
-bushings w/poly
-idler arm/ center link
-ball joints
Old Feb 3, 2002 | 03:49 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
You must have the cracks repaired by a welder or body shop first. Then install the "Wonder Bar". You probably have a cracked frame.
The only cars that don't seem to develop this problem are the IROCs. That all cam with the "Wonder Bar" from the factory.
Thanx,ANDYZ28
Old Feb 3, 2002 | 03:53 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
how easy would the cracks be to spot? I've looked under the car before and didn't notice any. Are they more likely to be behind the steering box?
Old Feb 3, 2002 | 04:11 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Yep!
Old Feb 3, 2002 | 05:47 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
if it is cracked behind the steering box would welding the crack and installing a wonder bar be good enough or should I weld on some sort of reinforcement plate behind the box?
Old Feb 3, 2002 | 07:24 PM
ANDYZ28's Avatar
Car: 1982 Z-28
That all depends upon the severity of the cracking. A 1/8" thick reinforcement would work just fine. If the reinforcement was "plug welded" then the welds ground flush. All that would be requiered would be to have the toe in reset. This is due to the 1/8" relocation of the steering box.
Thanx,ANDYZ28
Old Feb 3, 2002 | 08:44 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Thanx,ANDYZ28
I have a Wonder Bar on my IROC and my frame rail is craked. I am not sure what to do about it.
Old Feb 3, 2002 | 09:28 PM
ANDYZ28's Avatar
Car: 1982 Z-28
As I stated earlier. If the cracking is not too bad. Welding alone can solve the problem. But be certain that the welds are ground down flush. If the cracking is severe. Than it will require a plate reinforcement to be "plug welded" in place.
Thanx,ANDYZ28
Old Feb 4, 2002 | 12:58 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Even if it isn't a bad crack I was thinking of welding on a piece of high strength steel just as a precautionary measure. If I weld on a 1/8 inch plate behind the box, how bad would it through the alignment off? Also like I stated earlier in the post, it makes the popping noise when turning right probably because more preasure is being applied to the area of the steering box. Of course! But what causes the popping noise, is it the 2 ends of the crack rubbing together or what?
Frozer!!!
Jan 19, 2024 04:55 PM
Amillionoh7
May 24, 2020 08:01 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
zayne0
Aug 24, 2015 07:22 PM
