Rear shocks?
Old Feb 8, 2002 | 04:02 PM
BG87z's Avatar
Car: 1987 IROC-Z
Engine: Carbed 355
Transmission: TH-350
Rear shocks?
i am trying to remove my rear shocks. well when ever i turn the bolt on the top the shock just spins. i put vice grips around the shock but it still spun around. any tricks to getting it off?
Old Feb 8, 2002 | 08:33 PM
Belker's Avatar
Did you try soaking the nuts several times with WD-40 (or similar)?
Mine came off real easy. You could try grinding a flat spot on the shock so the vice-grips would grab better.
Old Oct 25, 2007 | 08:22 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: Rear shocks?
I am having this same problem anyone know how to do this, i was reading somehwere about a spring compressor but i dont see whut that would do ?? PLZ help i need it bad and quick
Rough
Old Oct 26, 2007 | 12:06 AM
2fast4u92z's Avatar
Car: 2 camaros 1 trailblazer SS
Engine: 346twinturbo, 383tpi
Transmission: t56 and 700r4
Axle/Gears: 3:46 4:11
Re: Rear shocks?
there isn't two cuts in the very tip of the shaft for like a 6mm wrench? Air tools and lub are your best friends.
Old Oct 26, 2007 | 05:40 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Re: Rear shocks?
I did the rear shocks on my 89 T/A a couple of months ago....
The top of the shock has 2 bolts so you will need 2 wrench's one on the bottom bolt and loosen the top bolt with the other one after I got the top one off I used the vise grips to hold the center rod of the shock (mine was flat on the top inch of the rod).
Mine came off easy.
Old Oct 26, 2007 | 07:41 AM
formula_pilot's Avatar
Car: 89 Formula
Engine: LB9
Axle/Gears: 9 bolt / 3:45
Re: Rear shocks?
If a shock gives me too much trouble like that, I grab a 1/4" drill bit and a drill, and it cuts through the nut pretty quickly. New shocks come with a new nut, so there is no need to keep the nut intact.
Old Oct 26, 2007 | 09:22 AM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Re: Rear shocks?
Originally Posted by Belker
Did you try soaking the nuts?
i am sorry but i had to, that just jumped at me haha
Old Oct 26, 2007 | 09:08 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Re: Rear shocks?
lol yea thats pretty funny!!!!
I see the top 2 nuts, there on there pretty good and its a crappy spot to work in, i wish i had air tools !!
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
deracer
Apr 11, 2016 12:04 AM
LT1Formula
Nov 16, 2015 01:13 PM
kevyb1973
Aug 24, 2015 04:11 PM
