How to change rear lugs?
Old Feb 11, 2002 | 08:06 PM
Abubaca's Avatar
OK, once the wheel, caliper, and rotor are off, what then? Please tell me the axle does not need to come out!!! Can I do this in my driveway with basic tools?
Old Feb 11, 2002 | 11:47 PM
turningfast's Avatar
Yes, but it is quite easy, and the gear lube is probably overdue for a change anyway. Pop the cover off first, and then remove the pin out of the carrier, which is only one little bolt. If you spine the carrier you will see the pin, it fits between the two axle shafts. The the c clip will fall out or be removed with pliers or a magnet. To do this push the axle in as far as it goes after the pin is removed. It's really easy, once you look at it, like changing a plug, but it smells worse.
Old Feb 11, 2002 | 11:57 PM
Oh yeah, you should replace the bolt that threads into the pin, but if you can't find it clean the pins threads and the bolt and use some thread locking liquid. ddon't forget to find the proper torqe spec and posi additive if needed
Old Feb 12, 2002 | 12:10 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Removing the axles isn't always necessary. I've swapped the wheel studs for longer ones without removing my axles. Just remove the items you mentioned. Then rotate the hub until the stud you want to remove is lined up with the space where the caliper was and bang it out with a hammer. The new one will slip in when in the same position, then using a 1/2" drive extension and a hammer drive it on from the back side. Be carefull to hit it on opposite sides of the head of the stud as you drive it in so it won't ****. In my case the rear end is a 9-bolt, so removing an axle is easier than the 10-bolts. But I've perfected this method after swapping wheel studs on both my rear ends. Good luck. Lon
Old Feb 12, 2002 | 07:21 AM
82camaro's Avatar
Car: 82 camaro SC
What he said, it can be done without removing the axles(if you are replacing the studs). The lugs just unscrew and you screw on the new ones.
Old Feb 12, 2002 | 10:59 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The lugs do not screw out. They are a press fit. You do not need to remove the axle.
You need a big hammer; just knock them out. Then put the new ones in and use a lug nut turned upside down, without the wheel or drum or rotor installed, to pull them in. Put some lube or anti-seize on the threads, you'll need to put alot of torque on the nut to get it to pull all the way through.
Old Feb 12, 2002 | 02:28 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
When you're done, throw that lugnut you used (to pull the new stud thru) in the toolbox in case you have to do this again. With the amount of force you need to put on the lugnut, you might not want to use it on the car again. At least; that's what I did; but I have old lugnuts lying around.
Old Feb 12, 2002 | 03:02 PM
Abubaca's Avatar
Ok...does hitting the lug with a hammer possibly damage the diff., gear, carrier, etc. ?
Thanks for the help.
Old Feb 12, 2002 | 03:14 PM
82camaro's Avatar
Car: 82 camaro SC
You won't damage anything, at least I've never seen it happen before. Around here they are called studs. The lugs(short for lug nuts) are screw onto the studs--RB83L69.
Old Feb 12, 2002 | 10:26 PM
Abubaca's Avatar
Wouldn't a lug nut be for a ....LUG? LOL
...but as they say, when in Rome...etc. etc.
customblackbird
Aug 15, 2021 10:16 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Omega
Oct 1, 2015 02:20 PM
kyleb24
Aug 15, 2015 08:24 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
