changing out axles...
Old Feb 13, 2002 | 04:59 PM
j166a99's Avatar
i'm in the process of changing out my driver side rear axle, and i want to know whether i should go new or junk yard.
is it even available new?
thanks fellas...
Old Feb 13, 2002 | 05:57 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
That all depends on what is wrong with the axle you are replacing
Old Feb 13, 2002 | 09:39 PM
j166a99's Avatar
actually Andy,
you're right, i meant to say the bearing, but should the axle go as well???
Old Feb 13, 2002 | 10:52 PM
turningfast's Avatar
Can you see a lot of wear near the hub. if so, you should. They don't call them axle eaters for nothing.
Old Feb 14, 2002 | 02:30 AM
ANDYZ28's Avatar
Car: 1982 Z-28
I remember a Chevy pickup truck in our shop that failed it's State Inspection because of a leaking rear axle seal. Once it was taken apart it was discovered that the bearing was bad, as well as the axle. But I remember that they installed some kind of bearing or something that did not require replaceing the axle.
Sorry I cannot recall much more detail. But it is a very busy shop. I will ask at work today. I'm sure someone can tell me about it.
Thanx,ANDYZ28
IROCtometal
Sep 20, 2015 11:08 PM
64goatman
Sep 9, 2015 01:09 PM
IROCtometal
Sep 9, 2015 10:01 AM
FormulasOnly
Sep 6, 2015 10:42 AM
luvofjah
Sep 3, 2015 07:08 PM
