Methods of checking engine mounts??
Old Feb 18, 2002 | 05:51 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
What are some of the methods I can use to check the conditon of my engine mounts. Right now I have a poly tranny mount with my stock engine mounts, is this bad?
Old Feb 18, 2002 | 06:13 PM
u r sofa king we tah did's Avatar
one way is to rev the motor with the car in park or neutral, and watch the motor with the hood up. if the motor moves your mounts are gone.
Old Feb 19, 2002 | 06:41 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
... you can also look around the bolt head on the motor mount (between the shell and the mount) and see if it's shiney, indicating movement.
And a poly trans mount is OK (maybe a lil noisy) with stock engine mounts.
I'll be changing mine when I do the front brake and suspension upgrade.
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
