changing steering box
Old Feb 22, 2002 | 02:09 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
im gonna get a ws6 steering box, how hard is it to remove install steering boxes? How much time should i set aside and anything special i should know first?
Old Feb 22, 2002 | 03:43 PM
Jza's Avatar
Jza
It's pretty easy and straightforward. You'll need a puller to remove the centerlink from the Pitman arm (or a different puller to remove the Pitman arm from the steering box if you're doing it that way). Using a fork to remove them will damage parts, and you don't want that since you're reusing them, not replacing them. You should also use line wrenches or in a pinch open-end wrenches, never a crescent wrench on the lines or you'll have a good chance of rounding off fittings. Basically, it's just one screw (to get the reinforcement bar out of the way), three large bolts on the box, two fluid lines, one bolt on the steering shaft, and one on the centerlink and you're done.
I did it in three hours because I also painted the box before I put it in, so set aside about that much.
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
Out-Cast
Mar 22, 2019 09:39 PM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
