What do I need to pull 1G?
Old Feb 25, 2002 | 10:35 PM
RB's84camaroF-41's Avatar
I'm planning on swaybars, eibach pro kit, wonderbar, poly bushings and 17'' wheels. Will this pull 1 full g?
Old Feb 26, 2002 | 10:47 AM
Dragula's Avatar
No. Chevy High Performnce did an article a while back. They took a black thirdgen to Hotchkis for upgrades. If I remember correctly, they did sway bars, subframe connectors, strut tower brace, lower control arms, panhard rod, and poly bushings. Running on 17" rims with 275 wide tires they were only able to come in just under one g. I believe it was .96g. It did perform better on the skidpad and slalom than lots of other cars including the new vettes (not the ZO6 though I think.)
You'll be close but not quite there.
Old Feb 26, 2002 | 11:50 AM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
killer autocross tires will make a huge difference too.
Old Feb 26, 2002 | 12:06 PM
Dragula's Avatar
Good point. They were only using street tires in the test mentioned above.
Old Feb 26, 2002 | 02:27 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
... if you already have the SFC's welded in, the STB and wonderbar installed, with the aftermarket Panhard Rod and LCA's with the re-location brackets, then your almost there.
With the ride height adjusted properly, the roll center aligned and about 1.5 degrees of negative camber your getting real close.
Now assuming that you have already got upgraded bushings thru out the suspension, about a 55 to 45 front to rear ratio and have compensated the weight transfer to the opposite side, you'll simply need to adjust the corner weights and you should be able to hit about 1.05g's.
I hope to be able to pull that this season, once I'm done with my 'project' car.
If you really want the formula to figure out the g's pulled, drop me an email and I'll send it to you. I just don't have it at work.
Old Feb 26, 2002 | 02:33 PM
Thanks for all the replies
Old Feb 28, 2002 | 11:46 AM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
neverland ranch? are you micheal jackson ?
wigmobile
Feb 26, 2025 02:56 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Amillionoh7
Sep 11, 2015 11:36 AM
sylentnite
Sep 9, 2015 02:55 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
