rear sway bar help w/ Ford 9"
Old Mar 10, 2002 | 09:04 PM
1988roc's Avatar
I'm trying to reinstall the rear sway bar on my 88 IROC 350 after I have installed a Ford 9". I have the Spohn Ford 9" rear sway bar install kit and am having problems deciding what the rear sway bar diameter is. I measured it with a micrometer and it reads .91 or 58/64 inch. Would this be considered a 7/8"? I am trying to locate the rear bushing kits and Energy Suspension shows their specs in millimeters. Is there a code on the console that will help me confirm what sway bar I have? I used a conversion website and it converts .91 inch to 23.114mm. Can I assume that I need a bushing kit for a 23mm sway bar? Thanks for your help.
Old Mar 10, 2002 | 10:39 PM
vjo90RS8's Avatar
Car: 2002 Z28
.91" is 23.114mm, so a 23mm swaybar bushing should work just fine.
Veaceonee
Sep 29, 2016 08:15 PM
FireDemonSiC
Sep 3, 2015 12:31 PM
The ODB
Feb 20, 2001 03:07 PM
BenIroc
Feb 16, 2001 11:29 PM
dragracer
Aftermarket Product Review
Jan 13, 2001 01:01 AM
