Coil Over vs. Working with the Stock mod. Strut set up
Old Mar 29, 2002 | 05:02 PM
GreenProStreet's Avatar
I am just getting into the chassis part of my G machine and wondering which is the better deal: a coil-over convestion or bolting aftermaket stuff to the stock modified strut unit? Pros? Cons? Thx, guys!
Old Mar 31, 2002 | 03:24 PM
Bump!!!
I know that alot of people have or are planning to installed coil-overs for autocrossing and roadracing. What I want to know is whay? ie. what are the advantages.
Old Mar 31, 2002 | 08:20 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
Unless you were doing AutoX I think coil-overs are kinda overkill. A good spring/shock or strut combo would be just as good for a car that isn't going to see any kind of road course.
Old Apr 1, 2002 | 02:32 PM
That is what the primary use of the car is going to be, other than hausling my but around. So why does coil overs work so well with autocrossing? Is it the adjustability?
Old Apr 1, 2002 | 03:17 PM
Hg's Avatar
Hg
Car: '87 Z
I'm guessing it's the adjustability... quite frankly, I'm not sure. Coil-overs are ALL th craze with the ricers at my school, that's what I stay away from them :lala:
If you are gonig to AutoX and can find a set for a reasonable price, go for it.
Old Apr 2, 2002 | 04:09 AM
Tas's Avatar
Tas
one of the main selling points of coil overs is the weight savings from the tubular K-member.
http://www.paracing.net/
It ain't free
Old Apr 2, 2002 | 05:18 AM
Norm Peterson's Avatar
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
It's the adjustability and how that benefits chassis tuning. In addition, springs for C/O's come in relatively small steps of stiffness.
Norm
Old Apr 2, 2002 | 03:04 PM
Thanks guys!
I did a bit of research and aggree that the popularity of the coil overs is the adjustibility of the ride hight and the wealth of spring rates and struts that can be bolted up. But as far as I can tell, the spring and strut are a unit hand have to be hydraulically pressed to fit together.
I am going to worry about wheels, tires and braks, before I do major suspension work!
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 25, 2015 07:34 PM
Thirim
Aug 13, 2015 03:09 PM
