Weight of front sway bar?
Old Apr 9, 2002 | 12:44 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
How heavy is the front sway bar of an IROC? Is it actually heavy enough to make a real noticable difference when drag racing? Everyone says it does but does anyone have actual results? I'm prepping my car for the track tonight and was wondering if its really worth the time taking it off.
Old Apr 9, 2002 | 12:58 PM
poncho9789's Avatar
I don't know that you will knotice a big difference from taking off the sway bar from the loss of weight but you will get a better launch and weight transfer off the line by taking it off.
*****be warned your car will not drive the same in corners and on the highway you will have to be carefull when driving to the track*****
Old Apr 9, 2002 | 01:16 PM
vjo90RS8's Avatar
Car: 2002 Z28
it depends if it is hollow or solid. I just removed my 30mm front sway bar and replaced it with a 36mm hollow bar. The hollow bar was so much lighter. I also heard that if you remove the front sway bar, you will be quicker in the quarter because more power is distributed to the rear. Try searching the boards.
Old Apr 9, 2002 | 10:06 PM
Car: '89 IROC-Z
I did do some searches but couldnt find an weight. Guess I'm going to be the first. I'll make a pass with the sway bar then one without it and see if there is any difference.
Old Apr 13, 2002 | 11:36 AM
bob8748's Avatar
do not drive on street without sway bar, done a lot of research on this. If you want the launch, remove drivers side end link at the track, then replace when fun is over.
Bob
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
