qhick question about my 1991 z28 350 tpi
Old Apr 10, 2002 | 11:14 AM
cridom's Avatar
I just bought it and what should i do first "my car is noisy ,but very fast
i wanna know what to do first sfcs,tune-up (eventhought the car runs perfectly),megashifter,or what?
any sugestions?
please reply
1991 z28 red camaro v8 5.7 350 tpi t-top
thanks
anyone wanna see pics?
Old Apr 10, 2002 | 01:03 PM
82camaro's Avatar
Car: 82 camaro SC
You could just ask all the questions with one post.
Megashifter, I have one and it works great--much better than the stock shifter. Subframe connectors are a must for every thirdgen, IMO. They all do the same thing(not really one that is the best). Look for sfc's that will clear stock exhaust and ones that others on the board have had success with. Get weld in ones. Spohn has good ones. I built mine.
As far as the noise, it could be alot of things--can you describe the noise and where it comes from?
As far as what mods to do, that depends on what you want your car to do. Look nicer, go faster, handle better, launch better. Drive it a while and let us know what you want to make 'better'.
basic tune up
alignment and front end check-up
check the brakes and tires
wash and wax
change all the fluids(never know how old they might be)
Those are some things I would do, since you just got it
Old Apr 10, 2002 | 01:09 PM
MikeS's Avatar
Even if everything seems like it is working great, go ahead and do a tune up first. Just to make sure. Then you can look to modify it. By the way, of course we want to see pics!
Old Apr 10, 2002 | 05:27 PM
cridom's Avatar
i found to noises one is fron the drivers door i think that i have to lift it a little bit cuz its a little bit loose the second one comes from the back and also if i turn the steering wheel all to the right or left and step on the gas something kinda pops under the engine.
thanks for the recommendations i think ill do sfcs and then shifter by the way is it too diff to install it myself i mean the shifter
the pics will come soon!!!!!
cya
i already have k&n and oil change so ill wait for a mayor tune up
(i want to make my car accelerate more because it seems to be too heavy and i wanted it to be like a rocket at starting)
thanks
:rockon::rockon::rockon:
Old Apr 10, 2002 | 11:15 PM
BOTTLEDZ28's Avatar
Transmission: A4
the poping noise you hear may be tie rods. when the steering wheels is maxed out and you turn the car, you put a lot of stress on the tie rod. if it is bad or your front end is way out of line then you may get that popping sound. have a shop give your car a front end alignment. while there there have them take a look at the whole suspension and see what condition it is in. how many miles are on your new ride. 3rd gen cars where prone to be noisy but GM got better at buildinghtem as years went on. if you wanna eliminate some noise you can add dyno mat to the doors and hatch area. it gets exspnsive depending how much you use but it helps a lot.
Old Apr 11, 2002 | 01:43 AM
Kandied91z's Avatar
how many miles on the new 350 or is it even a 350?
sub frame connectors will tighten the body and stop some of the typical noises.
megashifter will do nothing for you but look cool and get you to blow your first trans quicker. but, chicks dig it and old people can't get it out of gear so it keeps most from asking to drive!
as far as the poping noise, also check the ball joints.......i replaced everything before checking the obvious.
also, do a trans mount test; floor the pedal from a dead stop in a straight line...listen for any loud slams to see if it may be broken; originals don't last on highmilage cars. (don't exceed the speed limit either, you can test this with just a quick pedal press).
depending on mileage a tune up is always good; have your fuel pressure checked as well and if your air/fuel is off get an adjustable fuel pressure regulator or afpr!
if only drive on main streets and no freeways and you want to make it jump like a rocket add 3.73 gears.....if you don't want to loose at the strip and enjoy some freeway runs leave the gear alone.
one could go on and on about what to do, just do a search and keep looking at others posts to learn more.
Old Apr 11, 2002 | 11:26 AM
cridom's Avatar
this is the photo of my shock is it good? im new in this
Old Apr 11, 2002 | 11:31 AM
cridom's Avatar
Old Apr 11, 2002 | 11:49 AM
cridom's Avatar
this are some fotos of my baby!!!!!!!!
::rockon::::rockon::::rockon::::rockon::::rockon::
any comments of the pics?????????????????
Attached Thumbnails qhick question about my 1991 z28 350 tpi-sin-t-tulo-1
Old Apr 11, 2002 | 11:51 AM
cridom's Avatar
there are 165k miles on my 350 tpi baby !!!!!!!1
Old Apr 11, 2002 | 06:03 PM
Kandied91z's Avatar
how many miles on the engine swap?
350's never came stock with t-tops.
you could also use some new parking lamps!
Old Apr 12, 2002 | 08:03 AM
chevyguy1969's Avatar
Car: 1999 Camaro Z28
Engine: LS1 V8
Transmission: T-56 6spd
Where are the fog lights? Shoot some pics of the interior if you can.
Old Apr 12, 2002 | 08:43 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
lots of l98 came with t-tops. i know 2 of mine did.
by the way nice ride
Old Apr 12, 2002 | 08:50 PM
Kandied91z's Avatar
not on that model............
or any other 91-92.
but this isn't about that topic......i just wanted to know the condition of the engine since the swap since that combination isn't possible stock.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
redmaroz
Aug 16, 2015 11:40 PM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
