TBI Spacer...Has Anyone Tried This One?
Car: 1991 Camaro RS
Engine: 305 TBI
Is anyone useing or tried this TBI spacer. I'm wondering if the area between the bores produces the same properties as a TPI Air Foil. Seems to me that it would.
http://www.cfm-tech.com/tbispacer-1.JPG
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
IMHO, gimmick. The manifold is connected anyway. The foil of a TPI is intended to smooth out the corners of the throttle body. The air had already entered the TB when it passes the spacer.
Car: 1991 Camaro RS
Engine: 305 TBI
My main question is how much would this help atomization? My next question is what size are the bores... 1 11/16" or 2"? I have e-mailed CFM-Tech and am waiting on their answer.
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
I have talked to them before and they are very helpful. I have a spacer and found it to be an improvement. I made my own. I think the little notch is gimmicky.
Car: 1991 Camaro RS
Engine: 305 TBI
Thanks Treview1. I've got an open element ready to go on the 5-speed but just haven't had the time to do it. I'm considering this spacer also. I'll try to keep everyone posted.
Car: 2002 Z28
Car: 1991 Camaro RS
Engine: 305 TBI
I just got a reply from CFM-Tech. This is their reply:
"The bores are 1 11/16" and is 1" high. This plate will make as much, sometimes more, hp as adding a larger 2" tbi unit. The secret is not in the throttle bore size - it is in how much air goes thru it.
We suggest purchasing the Injector Spacer if the stock tbi unit is used. A high flow air intake will also be beneficial. More air = more power!"
Any opinions on their claims?
Spacer
Is it better? I don't know. I have a 2" bore spacer that is 1" high and didn't notice any significant gain from it. I had to have the spacer to fit the EGR valve because the TBI unit was too low.
Did it make a difference? I can tell you that from my experience, that it really didn't make much of a difference at all on my system.
Maybe it does. But not any seat-of-the-pants difference. I couldn't tell any difference before/after my spacer was put on.
rs_z28_vert
Sep 30, 2015 09:47 PM
