305/350 Tbi
Old Apr 29, 2002 | 06:29 PM
John Rock's Avatar
305/350 Tbi
Same body? Different injectors?? Ot totally different CFM?
Old Apr 29, 2002 | 07:00 PM
vjo90RS8's Avatar
Car: 2002 Z28
different knock sensors and injectors, thats about it, by looking at the 2 engines , probably couldnt tell the difference.
Old Apr 30, 2002 | 04:12 PM
John Rock's Avatar
But they flow the same CFM?
Old Apr 30, 2002 | 04:29 PM
vjo90RS8's Avatar
Car: 2002 Z28
yes, the TBI units themselves are the same, both 1 11/16" bores. If u want a higher flowing TBI, do the ultimate TBI mods, bore it out to 48mm, buy a Holley 670 CFM unit or try to find a GM 454 TBI unit.
Old Apr 30, 2002 | 04:36 PM
TimRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
The injectors are rated differently for 305's and 350's. Do a search in the archives for LO5. I'm considering the same swap for my 5-speed LO3 and have found a wealth of info there.
Old Apr 30, 2002 | 05:00 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Yep, same throttle body, bigger injectors on 350.
350 Truck Injectors:AC Delco# 17112493 (2 req)
350 Knock Sensor: AC Delco# 10456288
350 Knock Module: AC Delco# 16128261
-Rich-
Old Apr 30, 2002 | 07:50 PM
bigREd car's Avatar
Car: camaro
Engine: mighty 305
Transmission: mighty 700r
bore out the throttle body to 48mm??? where do we get the new throttle blades?
who does the ultimate tbi mods for 40 dollars i forget... if he does them do we have to send us our current throttle body before or after.. i just dont have time to learn or to take mine off... shot me an e-mail if you know.
i am trying to get a lo5 also we should all let each other know some round abuot prices and what not hard things and easy things since it looks like a few of us are doing it...
Shawn
Old Apr 30, 2002 | 08:16 PM
vjo90RS8's Avatar
Car: 2002 Z28
you can use the 48mm throttle blades from a stock TPI throttle body. I just bought 4 from a guy for 7 bucks.
Old May 1, 2002 | 05:33 PM
John Rock's Avatar
Thanks for the Info folks!!!! THats why I brought up the question, Im considering a Goodwrench LO5 350.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
