not to bring back oan old topic...but...whats the deal with an external AFPR???
Old May 8, 2002 | 01:08 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i am sick and tired of taking apart my TB every time i want to change my FP.
i did a search for en external AFPR, but didn't come up with anything good.
what are the possibilities?
looks like i need to make a block off plate for the existing one, then install the new one on the return line? am i correct?
anyone have any experience, or a website that has some info? any suggestions on which aftermarket AFPR i can use?
thanks...
-brian
Old May 8, 2002 | 01:10 PM
Snowdog 91 Formula's Avatar
Yes!!!!
Yes there is an alternative. Replace your throttle body with a Holley 502-5 for the 305 or the 502-6 for the 350. The AFPR is right between the injectors in the pod in the middle. All you need is an allen wrench to adjust it.
Old May 8, 2002 | 01:12 PM
Tas's Avatar
Tas
If memory serves me right: gut the stock fuel pressure regulator and put and external one on the return fuel line. I'd say serch under Pablos name but he has so many posts it might be impossible to find.
Old May 8, 2002 | 01:14 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
i have that thorttle body...it is garbage. well, the injector pod is anyways.
i am using that base with the GM pod with better injectors. i WISH it was that easy with the GM pod.
-brian
Old May 8, 2002 | 01:41 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
One of the guys on the Astro/Safari forum made a block off plate and used a Mallory 3 port return-style regulator.
He's got the block off plate where the OEM regulaotr is, and a pipe plug where the OEM return line was coming out of the fuel metering assy.
Old May 8, 2002 | 02:56 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
middle of page.............http://www.turbocity.com/TBIPowerMain.htm....
Old May 8, 2002 | 03:07 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
yeah, but that is still adjustable from under the throttlw body. i am looking for an in-line type regulator.
-brian
Old May 8, 2002 | 03:13 PM
wasp's Avatar
you dont have to remove the tbi tho, just your air box then reach your hand under and trun the dial, works for me anyway
Old May 8, 2002 | 03:26 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
really???? you can reach that from the back of the TB? sorry man...i didn't think that you could.
hmm maybe i will check that out.
thanks...but ideally i still would like an inliner, so if anyone has ideas, let me know.
-brian
Old May 8, 2002 | 04:12 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I have the Turbo City AFPR (and ported throttle body) on my 92 RS.
It's easily adjusted by just removing the air cleaner and twisting the ****.
-Rich-
Old May 8, 2002 | 04:43 PM
DM91RS's Avatar
Car: 91 RS
Try this:
https://www.thirdgen.org/techbb2/sho...highlight=afpr
I can turn it by reaching in with my fingers and only removing the breather.
Old May 8, 2002 | 08:53 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
sweet...thanks man.
-brian
Old May 14, 2002 | 11:36 PM
JPrevost's Avatar
Car: 91 Red Sled
-brian
Why is it garbage? Seems to work great for me. easy 10 to 20 psi with no troubles, just a 4mm allen key. GM injectors on it so no problems with injectors having fits.
Old May 15, 2002 | 04:32 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
yeah, yours must be the new style with the GM injectors..mine doesnthave them. it'sare the old style one. the chrysler ones or whatever.
does anyone know when the made the switch? i purchsed mine in june of 2000. it's the 502-6.
does this mean that on the newer ones that you can replace the injectors with any GM style injector? if so, i wonder if i can get just a pod from holley?
if anyone can give me this info it would be greatly appreciated.
-brian
Old May 15, 2002 | 10:47 AM
Brent's Avatar
Don't you have the 17112560 injectors and the GM vacuum reference regulator? You shouldn't need to adjust the psi other than getting WOT correct. I'd imagine you are with in 2-3psi of having enough fuel.
The HT502 conversion kit made 330 hp with those injectors and regulator.
I guess I'm just curious why you need to adjust FP.
Old May 15, 2002 | 05:30 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
i am assuming that you are talking to me...if not then ignore this post
yeah, i have the VAFPR and 80 pound injectors. but, i am learning to make my own chips, which means i dont need the vafpr any more. i can do it all right in the software...and it will be more accurate, and i can make small changes at certain RPMs, etc.
-brian
Old May 15, 2002 | 06:08 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
i seem to remember hearing that the vacuum regulator will help in tuning chips. I would keep it, and tune your own chips. Shouldnt hurt anything anyway.
Old May 15, 2002 | 06:24 PM
Brent's Avatar
I'd use the regulator you've got. It will probably make tuning idle much easier and its already got enough or very close to enough pressure for WOT (18-19psi).
The HT502 kit came with a custom prom also so I tend to think they needed that vac reference regulator.
Old May 15, 2002 | 08:50 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
oh ok..i was under the impression that it was better to have a "set" fuel pressure when doing EPROM tuning.
well, while we are on the subject...where is a good vacuum port to get the vacuum signal from for the VAFPR?
-brian
Old May 15, 2002 | 09:41 PM
snflupigus's Avatar
i think you want constant manifold vacum, splice off your map?
Old May 15, 2002 | 10:56 PM
JPrevost's Avatar
Car: 91 Red Sled
You're half right. You want to splice off the map sensor vac line which is tapped into the back of the throttle body. The constant vacuum source is actually used for stuff like the power brakes and climate controls, not sure about cruise because I don't have it anymore .
Old May 16, 2002 | 06:34 AM
snflupigus's Avatar
cruise vacuum is affected by the throttle blades, when closed there is little to no vacuum. vacuum increases as the blades are opened and air rushes by the little slit in the side of the bore.
so definately NOT what you want it tied off of for the vacuum reg or you would have what you want for wide open throttle fuel pressure at idle and idle fuel pressure at wot.
at least this is how the cruise vacuum is on the small block tbi. Wait or am i thinking of the thermac vacuum? Damn, I cant remember, I would have to go look, which i cant do right now.
anyway, listen to jon.
Old May 16, 2002 | 10:09 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
haha ok...
what about the spring situation? i know this has all been covered a while ago, but i wonder whatyou guys have to say now. i am assuming that some more experimentation has gone on with the vafpr since that monster thread a few months ago.
-brian
Old May 16, 2002 | 01:04 PM
Brent's Avatar
IIRC, people were discussing changing the spring because the original spring resulted in too much pressure for their application (ie - less than 330hp).
This shouldn't be an issue for you because your combo of injectors and regulator was used by GM to make 330hp. You will need the full pressure the regulator gives you unless you have some part(s) that restrict the engine (aka stock exhaust, etc).
Wylecoyote08
Nov 6, 2015 03:46 PM
backtothe80s
Sep 5, 2015 12:39 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
