Valve covers - how to and what kind?
Old May 21, 2002 | 07:35 PM
'89 IROC Vert's Avatar
Cast aluminum? Stamped steel? Which ones work better?
How hard is it to replace them? I've never done them before and wondered if anyone has a quick write-up about how to do it. Mine look like doo-doo.
Old May 21, 2002 | 08:58 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I am getting some Edelbrock Elite Series Valve Covers w/ Breather. I think they look real nice.
Old May 21, 2002 | 09:48 PM
TBI305Camaro's Avatar
um lets see just unscrew 4 bolts and remove...rough stuff...will be a bitch on the pass side if your emmissions are there tho
Old May 21, 2002 | 10:07 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
My favorite are these:
but I can't seem to find them anywhere
Old May 21, 2002 | 10:31 PM
That's all there is to it? Cool. I'll start searching. And you're right, all that smog crap above the passenger cover is going to make it a pain.
Old May 21, 2002 | 10:38 PM
Sonar_un,
http://ssl.adgrafix.com/cgi-bin/chec...anchSTORE:home
Old May 22, 2002 | 10:44 AM
105$ a set...is that a fair price compared to say a set of edelbrocks or something? i havent really been able to find any center hole ones anywhere
Old May 22, 2002 | 04:20 PM
DM91RS's Avatar
Car: 91 RS
These were $112 at Summit......
Old May 22, 2002 | 05:02 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i took mine out with all the smog crap there and cleaned them up and painted them high temp silver. they are dirty but you can kinda see em in this pic
Old May 22, 2002 | 06:47 PM
ZRATED's Avatar
Heres mine, I bought these at Pepboys for about 40$
Old May 22, 2002 | 08:15 PM
CamaroGuy71's Avatar
Car: 2002 TT Corvette
Engine: 5.7L
i got the 42 dollar ones from summit..same style as factory but chrome and the oil cap needs to be pushed on now instead of screwed on. replacing is easy. all u really need to get out of the way is the heater valve and the diverter valve. once those are out on the pass. side 4 bolts will take it out. gaskets are a bitch though. i stretched mione out around a garbage can so when i put them in they fit pretty close to where they should. centerbolt gaskets need to be stretched cuz they are rubbery for some reason and trying to put them on without stretching them is a pain. anyways, when ur ready, put some rtv..very little, is spots on the cover to hold the gasket in place during installation. also, make sure u disconect the battery b4 starting. torque should be about 15 ft. llbs on the bolts, just put them tight enough not to leak. any ques. email me... camaroguy72@aol.com
db057
Sep 4, 2015 07:57 AM
Thaney9
Aug 29, 2015 03:16 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
mustangman65_79
Aug 8, 2015 01:18 AM
