non egr vortec
Old May 24, 2002 | 09:31 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
non egr vortec
im going to be running a tbi'd vortec 350 (L31, all stock) and i know there is no egr provision with this engine combo. Im not sure of the CR ratio with these heads, perhapse 9:1 maybe? Anyone think I'll have problems with preignition knock? I hear some of the intakes (gm prerfomance) have provisions for a sort of backa@@ward egr system but if some of you are running these and not having much trouble ill just shoot for the non-egr edelbrock intake or something along those lines.
Old May 24, 2002 | 09:52 PM
Tas's Avatar
Tas
you can use EGR with the vortec TBI intake. If you use a Ford EGR valve, Edelbrock has plates that go under a 4 barrel carb that let you add EGR to a non EGR carb intake.
Old May 24, 2002 | 10:19 PM
steve8586iroc's Avatar
dimented, your going to need to burn a new chip for this setup so you might as well have the egr turned off and program your ignition curve accordingly. There are some good post on this a while back so you might do a seach on egr or no egr or something like that. I had a post saved but it will no longer come up, the page can't be found.
Steve
Old May 25, 2002 | 12:45 AM
super chevy's Avatar
Get the GMPP vortec carb intake with egr - then run a tbi adapter plate.
SC
Old May 25, 2002 | 07:59 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Check this out...
Im fairly sure thats EGR aint it? I came across it on ebay today...
http://cgi.ebay.com/ebaymotors/ws/eb...296173&r=0&t=0
Can someone explain it a lil more to me? Or if its even egr at all, lol
Old May 25, 2002 | 08:05 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
i very well could be wrong, but i think thats a heater-switch of some sort on the intake, not the egr (like i said - could be wrong) it just looks like the heater-core vaccuum switch in my TBI camaro.
TP
Old May 25, 2002 | 08:49 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Makes sense, thats where my friend Greg's coolant is routed on his Pro-Jection manifold.
Poo, I had a glimmer of hope for EGR, too
Old May 25, 2002 | 11:17 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Well... ihear egr can be done but i think a line has to be run from the exaust manifold/headers to the intake (i believe its the GMPP one)
Old May 26, 2002 | 05:00 AM
DM91RS's Avatar
Car: 91 RS
This would probably be decent except it's at least $100 overpriced at least to me......but it does have everything to make it work intake wise. You have to run a tube from your exh to the egr valve.
Old May 26, 2002 | 05:03 AM
DM91RS's Avatar
Car: 91 RS
Wrong one 1st LOL
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
