stupid question
Old Jun 1, 2002 | 05:27 PM
TMoNeE's Avatar
Car: 87 Z28
stupid question
i need to replace the valve gaskets how do i do it.. and is it pretty simple
Old Jun 1, 2002 | 06:53 PM
vjo90RS8's Avatar
Car: 2002 Z28
if u mean valve cover gaskets, then take off the old valve covers, remove all traces of the other gasket, clean the covers, buy a pair of Felpro gaskets from a local parts store, install them, and put the covers back on. thats it, very easy
Old Jun 1, 2002 | 11:31 PM
TBI305Camaro's Avatar
you should have rubber gaskets which means you wont even have to clean old gasket material off. just take out the 4 bolts holding the valve covers on, chuck the old gasket, place the old one in its place and put it back.
Old Jun 2, 2002 | 12:18 AM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
The actual changing of those rubber gaskets is pretty simple (maybe 1-2 minutes?), like TBI305Camaro wrote. However, it might be a bit of a PITA to get the valve covers off, depending upon how much of the stock engine foliage (AIR, HCV hoses, etc.) you have to pull out of the way... make sure you don't over-tighten the bolts - i think they're only supposed to be something like 7 ft-lbs.
Old Jun 2, 2002 | 01:52 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Im not sure I even have a passenger side valve cover, I havnt seen anything to prove otherwise.
Old Jun 2, 2002 | 03:19 AM
vjo90RS8's Avatar
Car: 2002 Z28
LOL
Cleotiz
Jan 6, 2018 08:56 PM
3.8TransAM
Sep 3, 2015 06:38 PM
masonta
Sep 1, 2015 06:40 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
