A small leap for TBI
Old Jun 15, 2002 | 08:23 PM
Slade1's Avatar
My sig says it all...
I'm now getting 255 RW Torque, whereas our puny LO3's had 255 torque at the flywheel! I've also made a 10 HP leap with engine HP as well. Now to see what this translates to at the track... I think maybe mid 15's.. perhaps breaking 90 mph?
Old Jun 16, 2002 | 12:08 AM
NJ SPEEDER's Avatar
congrats!
i hope to get to a duno befopre the end of the summer. i wanna see if the little LO3 can hit 305hp at teh wheels.
later
tim
Old Jun 16, 2002 | 02:22 AM
TBI305Camaro's Avatar
id be happy to see 305 at the flywheel.
Old Jun 20, 2002 | 03:47 PM
Mutiny32's Avatar
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
I'm going to a dyno here on the 29th. I'm gonna get a before and after mods comparison. The mods start showing up in the mail about a week after I get it dynoed
Old Jun 22, 2002 | 06:31 AM
91RS5spd's Avatar
Car: 1990 Camaro RS (IROC-Z Clone)
Engine: LO3
Axle/Gears: 3.08
torque is easy to get on our TBI's it hp that is the hard part for some reason. On my last dyno befor my cutout, pulleys, chip, and fanswitch. I had 275 pounds of torque and 163hp. Ill be getting new numbers soon.
Old Jun 22, 2002 | 10:54 AM
Slade1's Avatar
You won't get torque and hp to match up until 5252 RPM and even then its still pretty hard to do. Torque is easy to free up I admit, but you have to look at what mod does what in terms of torque and hp. Your HP is based off the acceleration factor generated by your max torque. Hence starting at 2400 RPM which is what a stock lo3 has a peak at torque falls off from there as the rpm goes up as the power (hp) generated goes up. So your torque and hp by 5252 rpm will technically be 1:1. Those who have done a dyno will see that the fall off on the curve and hp will come to a single intersecting point. At a certain point it becomes hard to generate any more hp because its almost litterally used just to sustain that rpm. mods that increase hp more than torque are mods that will increase rpm capability. Mods that have no affect on rpm, but increase airflow effeciency and that will generate torque more than hp. You eventually hit a balance between the two as you'll find you get limited by other factors. The point is right now lo3's are severely airflow restricted. This keeps rpm down and torque down.
Old Jun 22, 2002 | 12:29 PM
91RS5spd's Avatar
Engine: LO3
Axle/Gears: 3.08
amen:rockon:
db057
Apr 28, 2019 07:45 AM
Jorlain
Oct 8, 2015 01:57 AM
64goatman
Sep 9, 2015 01:09 PM
BOOT77
Sep 5, 2015 03:55 PM
Billy Decker
Sep 4, 2015 03:46 PM
