bumping timeing, what the hell did i do?
Old Jun 30, 2002 | 06:53 PM
91RS5spd's Avatar
Car: 1990 Camaro RS (IROC-Z Clone)
Engine: LO3
Axle/Gears: 3.08
Well, I tried to bump my timeing and I don't think I did anything, I rotated the distrib, but nothing happened, I was told the rpm's would go up and when it is where I wanted the car to idle, to stop and tighten the distrib down. But none of that happened, my rpms would go up to 1000rpm but then it would fall again to 750 where it usally is at idle. So whats up, is their a step im missing or am I going about this all the wrong way?
Old Jun 30, 2002 | 09:34 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
disconnect the timing bypass connector in teh wire loom over the blower motor and use a timing light to time it. Directions should be on the underside of the hood as to what to set the timing to.
Old Jul 1, 2002 | 06:16 AM
91RS5spd's Avatar
Engine: LO3
Axle/Gears: 3.08
thank you
Old Jul 1, 2002 | 10:10 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I was able to run 7* of timing on a stock motor with 92/93 octane without ping. I think most people can run about 8*, but dont quote me on that one.
1992 Trans Am
May 10, 2023 07:19 PM
mhatfield 14
Oct 24, 2015 07:48 AM
86IROC112
Aug 20, 2015 12:18 PM
novaderrik
Aug 10, 2015 12:44 PM
86Base
Aug 8, 2015 01:34 PM
