Open element question???
Old Jul 5, 2002 | 12:36 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
I just put on my open element w/ the Xtreme lid, and let me just say WOW!! I had no idea it would do that much...:hail:
One thing I am wondering though....I already have the thermac device plugged from earlier modding, but now my "service engine" light is on, which I believe is due to the fact that I left that little sensor from the original cleaner unplugged.
How do I get the other half of that thing out of the original air cleaner housing?? I'm just not very comfortable w/ that light on. And second, the drop base on my new filter has a little indention that looks as though if I punch/drill it out, that's where the new sensor should go, but it looks a little big? Any ideas on how to get that thing out?
Old Jul 5, 2002 | 03:58 PM
Car: 91 RS
Engine: 350 TBI
All right never mind that part, takin' care of.....new question.....What are yall using in order to seperate the base of the housing from the coil wire?? Right now I just have a piece of cardboard shoved in there, but there's got to something out there that looks better????
Old Jul 5, 2002 | 04:29 PM
Tas's Avatar
Tas
you get a flat base air cleaner?
Old Jul 5, 2002 | 05:27 PM
Car: 91 RS
Engine: 350 TBI
Nope....drop base
Old Jul 5, 2002 | 10:31 PM
foxandfoe's Avatar
no he's telling you to get a flat base air cleaner? that will do it and it will fit under the hood.
Old Jul 6, 2002 | 03:48 AM
Tas's Avatar
Tas
I meant to say "got" insted of "get" but whatever.
Old Jul 6, 2002 | 03:25 PM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
Unbolt the coil and move it back, mine has been this way for a long time with no problems
Old Jul 7, 2002 | 11:06 AM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
Is this what you're referring too? If it is, Just like MightyMouse said, just loosen the coil pack mounting nuts and pivot the coil pack away and retighten.
Old Jul 7, 2002 | 11:50 AM
Car: 91 RS
Engine: 350 TBI
Thanks, I'll try that.....
Old Jul 7, 2002 | 02:34 PM
Jokerman's Avatar
Engine: slowtacular L03 305
Transmission: slushem 700r4
which base is gonna be the least amount of work drop base or flat? I feel the urge to burn a few bucks here soon and would like to know.
Old Jul 7, 2002 | 02:36 PM
Tas's Avatar
Tas
flat base flat base always get flat base with TBI. Did I mention to get a flat base?
Old Jul 7, 2002 | 04:52 PM
Car: 91 RS
Engine: 350 TBI
I just used the same open element that I had on my last project (72' Lincoln); so the only thing I did was clean the filter and that was that...maybe next I'll take off the MSD 6AL box and 750 double-pumper....
Old Jul 7, 2002 | 04:59 PM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
So that piece he's talkin about can be swiveled away?..i just did the same thing..and posted the same question elsewhere..right now i just got the cleaner resting on the wire, its insulated and i havent had a problem but i really wnana fix that
Old Jul 7, 2002 | 07:53 PM
Jokerman's Avatar
I was looking about and found one of the perforated screen style air cleaners. Has anybody used one on a tbi and are the clearance issues the same or non exsistant? Link for it just so you can see it. Click this...
Old Jul 7, 2002 | 08:08 PM
Tas's Avatar
Tas
those aren't good. The foam breaks up and gets in your engine.
Old Jul 7, 2002 | 08:24 PM
Jokerman's Avatar
Ahh, oh well. I just thought that it might be an easier alternative to messing about with wire and throttle linkage clearances.
Old Jul 7, 2002 | 08:31 PM
Tas's Avatar
Tas
flat base air cleaners don't have those problems
Old Jul 7, 2002 | 08:52 PM
Car: 91 RS
Engine: 350 TBI
The drop base has no problem clearing the linkage and I get to use a taller filter.....only beef is with the coil wire.
Old Jul 7, 2002 | 11:46 PM
TBI305Camaro's Avatar
drop base cleared my coil fine but it messed with the throttle/TV cable bad...pushed on it and sat funny so i went and bought a cheap non drop base...much better. Why raise a drop base with a spacer ring? i got lucky and found a big drill but that was the PERFECT size for the sensor your talking about. screwed it right in. even in very hot weather the open element is still worlds better than the stock cleaner.
Old Jul 7, 2002 | 11:52 PM
Snowdog 91 Formula's Avatar
Flat base
Definitely go flat base. All your clearance issues will vanish. Plus you will have better airflow without that spacer on the drop base.
Old Jul 8, 2002 | 11:02 AM
Car: 91 RS
Engine: 350 TBI
I didn't require a spacer; its base already has notches molded into it so it doesn't require any spacers. I had used it originally on a 750 double-pumper on a 460.
Frozer!!!
Jan 19, 2024 04:55 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
redmaroz
Aug 16, 2015 11:40 PM
wruiz
Aug 13, 2015 09:07 PM
