replacement tbi
Old Jul 7, 2002 | 08:00 PM
The Chad's Avatar
Car: 84 berlinetta
Engine: lg4
Transmission: 700 r4
replacement tbi
Where can I find a stock or better tbi unit to fit my 1992 cxmaro rs 305. Is BBK the answer?
Old Jul 7, 2002 | 08:09 PM
Tas's Avatar
Tas
TBI from a 454 big block
Holley 670cfm TBI
turbocity bored out stock TBI www.turbocity.com
Old Jul 9, 2002 | 11:04 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I'm using the Turbo City Ported Throttle Body.
Works Great.
-Rich-
Old Jul 18, 2002 | 05:06 AM
NOCANDO's Avatar
Hey Rich, how much did it cost for the ported TBI and was it easy to install??
Old Jul 18, 2002 | 09:17 AM
Car: 92 Camaro RS
http://www.turbocity.com/
$229 plus the $200 refundable core charge.
It bolted right up, and the larger bores cleared the Edelbrock
Performer TBI intake with just a slight chamfering on the intake bores. Nice looking piece too.
I did have a vacuum leak after I put it on. Seems the one I got was a little warped on the bottom.Just needed to clean it up with a steel block wrapped in sandpaper. I suppose I could have sent it back, but I already sent them my core, so my car would have been down.
I also used their Adjustable Fuel Pressure Regulator, and it's easily adjustable by just removing the air cleaner. It's pretty easy to make the stock one adjustable (see ultimate TBI Mods), but lately I have more money than time, so I bought theirs.
Reason I didn't use the Holley Throttle Body was that I'd heard their injectors were not very tolerant of fuel pressure increases, but I've heard that they've corrected this problem by using a different type of injector now than they used to.
-Rich-
Old Jul 18, 2002 | 11:16 AM
jordanz28ss's Avatar
how good does the ported tbi flow compared to the holly 670?
Old Jul 18, 2002 | 11:25 AM
Car: 92 Camaro RS
I hear it's around 580-600 CFM.
-Rich-
Old Jul 18, 2002 | 07:20 PM
Coop89RS's Avatar
Hey Rich92 I have the turbo city TB with the adjustable fuel pressure regulator. I haven't touched it in so long I forgot how it works. Which way for more fp and which way for less, also what r you using to tell you what your fp is.
Old Jul 19, 2002 | 07:43 AM
Harley61's Avatar
Car: 90 RS / 89 IROC
Engine: 305 TBI / 305 TPI
Transmission: 700R4 / T5
Axle/Gears: 3.73 / 3.08
What about the turbocity "Matched Injectors"? Anyone have any comments about those?
Old Jul 19, 2002 | 09:13 AM
Car: 92 Camaro RS
Turn the screw in (clockwise if you're looking at it upside-down) to increase pressure. I have a fuel pressure gauge on the supply line between the frame and motor (in the flex-line).
-Rich-
92camaroJoe
Jul 29, 2023 07:57 PM
dutch930
Sep 11, 2015 06:58 AM
92camaroJoe
Aug 13, 2015 06:07 AM
92purpz28
Aug 11, 2015 02:30 PM
