Question about edelbrock TBI intake
Old Jul 7, 2002 | 11:52 PM
TBI305Camaro's Avatar
Ok say i was to swap in a 350 soon and wanted to go with the holley 670 cfm TBI could i have the bores of the edelbrock intake bored to work with the larger bore size of the holley TBI? My uncle owns a machine shop so i figured it could easily be done.
Old Jul 8, 2002 | 12:43 AM
Tas's Avatar
Tas
Someone said they did it. I wouldn't want to do it to a new intake. Maybe a used one.
Old Jul 8, 2002 | 12:22 PM
iroc22's Avatar
Doubt you will actually be able to pull it off. There's water jackets sitting all around the throttle bores. Do yourself a favour, and buy a 4bbl carb intake and get a TBI adaptor. You'll make more power because you'll be increasing plenum volume, and carb intakes are much cheaper.
Old Jul 8, 2002 | 02:34 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Edelbrock only recommends chamfering the bores.
As iroc22 said, there are passages you'll likely cut into, if you bore it straight thru. If you're going with the big throttle body, you'll be better off using the Holley manifold or a 4-bbl intake with an adapter plate.
-Rich-
Old Jul 8, 2002 | 03:10 PM
Tas's Avatar
Tas
found it
https://www.thirdgen.org/techbb2/sho...elbrock+intake
Old Jul 9, 2002 | 12:34 AM
well i went to jegs this morning and went ahead and got the intake, trans cooler, and a hypertech cool fan switch. I decided i probably wasnt going to get a bigger TBI since i dont think the combo i plan will need it. I plan on a LO5 with a mild cam with the TBI intake on top with some 350 injectors. wont be to crazy maybe 250ish HP with the right chip. then i may add alittle giggle juice
Old Jul 9, 2002 | 12:53 AM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Why not just go with the Holley intake. It already has the 2" bores.
Old Jul 9, 2002 | 01:26 PM
i hear the holley manifold takes alittle modding to make everything hook up plus its like 1 1/4'' taller than stock and with a 3inch element i dont have much clearance
Old Jul 9, 2002 | 01:31 PM
iroc22's Avatar
Yeah clearance is an issue with that Projection manifold.
Old Jul 9, 2002 | 01:40 PM
Tas's Avatar
Tas
It would be nice if NJ Speeder would go to the track with his 670, Projection intake, and LT1 cam on his 305 so we can see what's up.
Old Jul 9, 2002 | 03:45 PM
iroc22's Avatar
Yeah that's how I wish too. I G-teched my car as a 14.4, but that cannot be used as an accurate time (although it was a really flat test strip I used). I know how it is to be busy and not have time when the test and tunes come up. Sometimes the track schedules dont work with yours.
Old Jul 9, 2002 | 08:39 PM
im having some problems with the intake now. i guess where the TBI sits further back the kickdown cable is coming off...plus im leaking coolant somewhere...hoping its not from the intake itself
Old Jul 9, 2002 | 10:43 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
You don't have a kickdown cable. The only cables that are attached to the throttle linkage are the throttle cable, the TV cable, and cruise control if you have it.
If you aren't experiencing any major driving problems, then I'll venture to say it's the cruise control.
As far as water leaking, where does it drip from?
AJ
Old Jul 10, 2002 | 12:30 AM
i cant tell exactly were its leaking from yet its dark by the time it was finished. The one falling off is the sliding one. the brass one i was told its the kickdown cable. the TV cable is definetly not adjusted right im gonna do that in the morning. something is definetly not right tho.
its dripping from near the tranny bellhousing so its near the back somewhere. could be the new fan switch i installed im not positive yet. Ill figure it out in the morning
MustangBeater20
Oct 29, 2022 09:20 PM
dutch930
Sep 11, 2015 06:58 AM
86IROC112
Aug 17, 2015 02:00 PM
redmaroz
Aug 16, 2015 11:40 PM
89-S-dime
Aug 12, 2015 11:57 AM
