Ultimate TBI Fuel Pressure mods
Old Jul 9, 2002 | 07:46 PM
alohamike's Avatar
Been reading the instructions for the AFPR mod. Looks pretty straightforward. I can see my tab and looking at it from the top down, it appears to be at or near the bottom of the cup so I presume the fuel pressure is as low or as near to as low as it can be...correct?
Before I start any of the mods, I plan check my mixture with the method described using the 02 sensor and voltmeter, presuming if the voltage checks out as recommended, I won't need to make any changes in the TBI FPR...correct?
But, if adjustments need to be made, does anyone have a ball park figure for the relationship of how many turns of the FPR screw will give how many additional pounds of pressure? If the pod needs to be disassembled every time an adjustment is made, I'd like to get as close as possible the first time.
Many thanks! :hail:
Old Jul 9, 2002 | 08:42 PM
Dex's Avatar
Dex
It is REALLY simple to do it I think the the little window deal that tells you where your fuel pressure is at. the higher the cup the more fuel pressure the lower the cup the lower the pressure its simple I think
and its not that hard or time consuming the the adjust the fuel pressure 8 torx screws and few twists and your done not hard took me 2 min i think
Old Jul 9, 2002 | 10:11 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
My stock fuel pressure regulators tab was set near the bottom also (looking from the top down) but, before I adjusted anything I decided to mount a Fuel pressure Gauge inline so I could see what the actual fuel pressure was. I'm glad I did it because as you can see, my fuel pressure is 12psi and sometimes gets to 13psi without adjusting anything.
Old Jul 10, 2002 | 03:36 AM
alohamike's Avatar
GKK,
I'm not positive, but what you're measuring is the line pressure going to the TBI. The regulator inside the unit adjusts that pressure to the injectors. I don't know how you'd measure that except to monitor the O2 sensor at WOT to make sure it's spitting enough gas to get the voltage up between .8 and .9mv.
Old Jul 10, 2002 | 09:42 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Originally posted by GKK
My stock fuel pressure regulators tab was set near the bottom also (looking from the top down) but, before I adjusted anything I decided to mount a Fuel pressure regulator inline so I could see what the actual fuel pressure was. I'm glad I did it because as you can see, my fuel pressure is 12psi and sometimes gets to 13psi without adjusting anything.
That's a very clean engine
Who makes that gauge you have?
Old Jul 10, 2002 | 11:22 AM
GKK's Avatar
GKK
Originally posted by alohamike
GKK,
Think of the Stock Fuel Pressure Regulator as a Garden Hose with your thumb partially covering up the end of the hose; all the water in the hose before your thumb is pressurized and goes to the injectors, all the water that sprays past your thumb goes to the return line and back to the Fuel Tank. Also, for Gunny Highway, that's a Summit Liquid Fuel Pressure Gauge. Costs $19.95 part #SUM-800115.
Old Jul 10, 2002 | 11:29 AM
Car: 91 RS
Engine: 350 TBI
And I can use that to adjust my pressure w/o any wierd procedures??....like just twist a **** and it's done??
Old Jul 10, 2002 | 11:50 AM
GKK's Avatar
GKK
Oops, I meant to say I installed a fuel pressure "Gauge" not Regulator. If you installed an inline fuel "Gauge" and found your pressure too low, then you would have to make your stock fuel regulator adjustable and increase the fuel pressure while watching the fuel pressure change on your new Fuel Gauge.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
