How to make it faster Need help
Old Jul 16, 2002 | 01:39 PM
91redbird350tbi's Avatar
Hello, I got a 91 firebird with a 350 .60 over. 2.5 in flowmaster exhaust. No headers stock manifolds. I am wanting some Ideas on what I should or can do to make my car faster. Any help would be greatly appreaciated. Thanks
Old Jul 16, 2002 | 03:27 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Start with exhaust from the engine back. Get complete mandrel bent system for a single cat TPI car that way you can get 3" y pipe from the headers (brand is not real important) and a Catco 3" CAT and 3" CATBACK (again brand is not that important). Then you need 3.23+ gears and posi. Being a 91 you can run the famous $99 Zexel posi from SLP and get some gears. I am partial to the 3.42 gears. I have run that ratio in several cars and found them to be a great street gear.
Old Jul 16, 2002 | 04:29 PM
Thanks for replying. Will that setup work even know I have a tbi setup. Thanks
Old Jul 16, 2002 | 06:23 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
yes it will.
Old Jul 17, 2002 | 01:18 AM
TBI305Camaro's Avatar
any exhaust setup for a third gen will work...82 -92
Old Jul 17, 2002 | 11:18 AM
iroc22's Avatar
Is it a roller block? If so, I would grab maybe a LT4 cam while you're at it. If not, you're choices for aftermarket cams are endless and already cheap.
Old Jul 18, 2002 | 01:50 AM
cams for roller motors arent exactly cheap. Usually about 250$ a pop.
Old Jul 18, 2002 | 12:08 PM
iroc22's Avatar
Yeah I was tryin to say to grab a roller cam from a factory engine because it can be had for less. And if its a flat tappet cam, then his choices are endless. I was a little unclear in my post.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Grant2k
Jul 10, 2018 04:01 PM
mustangman65_79
Apr 14, 2017 05:37 PM
toones
Jan 6, 2016 06:00 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
