View Poll Results: what t do with my 90 rs....
blow it up
38.46%
ride it out
53.85%
don't care
7.69%
wanna buy it
0%
Voters: 13. You may not vote on this poll
just my luck....
Old Jul 20, 2002 | 02:51 AM
fakezcar's Avatar
just my luck....
I've got the motor in ready to go...turn the key...crank no fire....adjust timing.....no fire......continue for 20 minutes.....check coil spark.....weak.....input voltage good......Next step...new coil!!!! That's after the coolant leak is noticed at the therm. housing......crappy alum. edelbrock!!!! I'm fed up ready to throw some fertilizer in the friggin' gas tank.....if she doesn't fire in the morning I'm gonna blow her up!!!!!!
Old Jul 21, 2002 | 11:28 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
sounds like all teh crap mine used to do. Hang in there and work through it all. When i got mine i couldnt even drive it. Sat for like 8 months in my garage. Needed alot of work.
Old Jul 22, 2002 | 01:54 AM
TBI305Camaro's Avatar
Mine ran fine the first day i had it. The next morning it started fine but didnt want to stay running. This was last year when i didnt even know how to change oil. The problem didnt go away and i started replacing all kinds of stuff i didnt need to. Then 3 months later suddenly it just stopped running. So I started thinking and checked...no fuel. So I went through the task of changing the fuel pump with no car knowledge. walla ran perfect after that. Just hang in there man. Hell if my car never broke I still wouldnt know anything about cars and it probably wouldnt have any mods.
Old Jul 22, 2002 | 10:34 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Just ride it out dude.....
Remember , "that which does not kill us , makes us stronger!"
I too have, on occasion, had one problem after another.Don't get discouraged.Just keep plugging away at it and it'll work out.
When it is running good and you're driving it, it'll all be worth it.
-Rich-
Chuck84TA
Carburetors
27
Jun 16, 2015 07:49 PM
Riverboyskennel
Jul 10, 2014 07:19 PM
Papa Ken
Fabrication
Jan 26, 2013 12:28 PM
BluFBdy
Feb 6, 2011 09:14 PM
BluFBdy
Dec 8, 2010 02:29 PM
