help me!! tbi dumping too much gas...
Old Jul 20, 2002 | 06:25 PM
InTeRcEpToR5.7l's Avatar
i am swapping my 305 tbi for a 350 with the same tbi.... well i got everything hooked up today and turned her over, my tbi is spraying sooooo much gas,,, what could cause it to do this? i mean it sprayes enough to nearly fill up the barrels or whatever you call them... please help me out i need to know ...thanx guys
Old Jul 21, 2002 | 04:47 PM
REBIRTH's Avatar
I would make sure that you have 350 Injectors and a Chip. Does the Computer give you any error codes?
Old Jul 21, 2002 | 10:40 PM
CamaroGuy71's Avatar
Car: 2002 TT Corvette
Engine: 5.7L
tps? if the tps thinks its at wot at idle it could do that
Old Jul 21, 2002 | 11:04 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
yes... make sure the tps wasnt put on backwards... I heard of that happening before... Also check all the gaskets and such
Old Jul 21, 2002 | 11:11 PM
WarlocV's Avatar
The injectors for the 350 have a higher flow rating. Put the old injectors in the new one and see if that works.
Old Jul 21, 2002 | 11:16 PM
REBIRTH's Avatar
Good call CamaroGuy71, forgot about that.
Old Jul 22, 2002 | 10:35 AM
which is the tps? i will try and turn it around.....(sorry im an idiot)
Old Jul 22, 2002 | 11:51 AM
Car: 88 Camaro SC
Engine: SFI'd 350
if you look at the tbi, the tps is directly opposit the throttle linkage on the shaft. Its a black rotary sensor on the tbi with a four pin connector going to it. You can measure the tps to see what the resistance of the sensor is. it should have its lowest resistance when its closed and the highest resistance at WOT. Youll have to find which of the four pins connects across the rotary resister. After you verify that its hooked up properly, then you can backprobe it to see what the voltage is. Should be like .7 at idle, 4.6 at WOT or soemthing. This is usually covered in most shop manuals for your car. Good time to get one if you dont have it. If you havnt had the tbi all apart for mods and cleaning then i doubt its on backwards. If you have had it apart then check to see that none of the o-rings sealing the injectors are leaking. Well, id check them anyway. Turn the key to the on position to let the fuel pump prime the system and look to see if gas is leaking out. If not, then you have a problem elsewhere. Maybe an erratic reference pulse from the dist. or something.
Old Jul 22, 2002 | 10:16 PM
yall are never gonna guess how simple the prob was.!!! it was the grounds, they werent connecting.. lol!!
Old Jul 23, 2002 | 03:02 PM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
My car is a 89rs with a 355 tbi and it is doing the same thing as yours. But i have a new tps and it didnt do any thing for it. But mine when i push the gas the ingetors dont spray that much but if your foot is off the gas it sprays like crazy. check to see if yours does the same thing maybe we can both figure what the heck is wrong with these cars.
Old Jul 23, 2002 | 05:05 PM
Car: 89 Camaro RS
Engine: 355 TBI
what grounds are you talking about i have the same prob.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Gordonr1973
Sep 29, 2015 11:59 AM
