running rich
Old Jul 29, 2002 | 10:05 PM
91eagle's Avatar
Car: 2004 Dodge Stratus Coupe R/T
Engine: 3.0 V6
running rich
My car (91 Firebird) is running really rich. I was wondiner if anyone could give me ideas on what to do to fix this problem. So far I have adjusted the idle (not sure if I did everything correct on the IAC (could use more detailed information)). Before I did this I replaced distributor cap, rotor, plugs and wires. Shortly after this my thermostat guage quite working.
Can anyone help me out?
I was wondering if it might be the oxygen sensor and/or the temp sensor.
:hail:
Thanks for all of the help ahead of time. I want to fix this on my own if possible.
Old Jul 29, 2002 | 10:39 PM
91eagle's Avatar
Engine: 3.0 V6
forgot to add
I forgot to add how the car runs.
When I ahve started it in the morning it is very hard to start. It starts and acts like it is not getting enough fuel. Since I drive only a short distance to work it does not have time to warm up. When I leave work for lunch it is the same. After work if I drive it for a while it warms up and runs decent the rest of the day (still rich though).
However I did not understand about the IAC until tonight and did some more work with the car. I am not sure however that I did everything. I will know more when I go to work in the morning (5 am.=).
I would like a detailed description of what to do with the IAC and how to look at it to figure out if I did the paper clip right.
Just remember that I am new at this and I am trying to learn as much as I can so that I can do 90% of the work on my car (especially the engine).
Thanks again.
Old Jul 29, 2002 | 11:01 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
you could try replacing the coolant temperature sensor. I cant think of any way to verify its working w/o using winaldl. I guess you could always measure the resistance across the sensor itself but i dont know what resistance coorespods to what temperature. Does the ses light come on? Also, a bad o2 could cause this, too.
Old Jul 29, 2002 | 11:02 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Pobably a good idea to make sure the injectors/pod isnt leaking any fuel.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
