LT1.. or more?
LT1.. or more?
Since this got brought up in a thread that got closed before I could ask more... should I go with more than an LT1 cam?
Planned combo:
Fresh 10:1 350 Shortblock
Ported L98 Iron heads
LT1 Cam, 1.6 RRs
Edelbrock TBI intake
Ported/Worked TBI unit with 350 injectors
switch to 8746 ECM with 350 Caprice COP PROM
What I want out of it:
Daily driver motor that pulls decent MPG, can handle road trips, can start in cold weather, and pushes enough HP to run mid/high 14s. (Assuming good traction, 3.42 rear end and rebuilt tranny, those will be happening sooner or later). And it can't cost that much. I'm on a college budget, but the present motor is beat to hell and needs replaced. Always replace it with something better.
Since its still in the planning stages... would the LT1 cam be enough to pull this off, or would I be better off with something else? It has to pull good idle vacum to keep the computer happy. And I want my peak HP about 5000-5500 RPMs. LT1 cams are nice and cheap on eBay, and not all too hard to come by.
Planned combo:
LT1 Cam, 1.6 RRs
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
With your new combo, I would think you would pull low 14's with it. If you add a 95 4.3 S10 torque converter while your at it you may pull high 13's or at least very low 14's. Lt1 cam really runs nice in TBI cars compared to the peanut cam TBI's cam with. 1.6 rockers may push the limit of the stock L98 heads unless you have them machined for that much lift.
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Travis will be gitting rid of his cam in the LT1 provided its stock or a mild one. YOu can buy his b/c this will be around the time you want to do your engine.
Since you'll probably talk to him before me, tell him I'm lookin at LT1 cam, His TBI unit, and ECM+Chip.
He wants to keep all of throttle body and computer just in case he sells the car. But I think you can score the cam though.
I've been doing some comparing of specs on SDPC.....
lt4
Duration @ 0.050 (I/E): 203/210
Lift, (I/E): .476"/.480"
Lobe Separation: 115
RPM Range:
Type: Hydraulic roller LT4 Production Cam
lt1
Duration @ 0.050 (I/E): 201/208
Lift, (I/E): .447"/.459"
Lobe Separation: N/A (I've heard its 116)
RPM Range:
Type: Hydraulic roller tappet
lt4 hot
Duration @ 0.050 (I/E): 218 / 228
Lift, (I/E): 0.525" / 0.525"
Lobe Separation: 112
RPM Range: 1500-6000
Type: Hydraulic roller LT4 Hot Cam
Comp Cams 262HR-12
Usage: Fuel Injection
Advertised Duration Int.: 254
Advertised Duration Exh.: 258
Duration @ 0.050 (I/E): 206/210
Lift, (I/E): .450/.480
RPM Range: 1000-5000
Type: Hydraulic Roller
The thing that keeps me concerned is idle vacum and computer-happiness. The refular LT4 looks almost the same as the LT1, just with a bit more lift and 1 degree less LSA. If I just got 1.6 rockers I'd pick up that extra lift.. and if I can get a deal on a set... the LT1 might still be the cheapest route unless I find a used LT4 cam. Price is very important, my working budget is pretty shoe-string. Would the more agressive LSA of the LT4 HOT kill my idle vacum, start good in the cold, or be too much cam with the mild intake/heads? Don't wanna miss-match after all. I'm not saying who suggested it was off... I'm just asking lots of questions before I spend any $$.
lt4
RPM Range:
lt1
RPM Range:
lt4 hot
Comp Cams 262HR-12
Car: 89 Camaro RS
Engine: 355 TBI
i have an 89 355 tbi camaro, and i was just wanting to know if i put the lt4 hotcam kit with the 1.6 roller rockers, will i have to do any thing to the stock 350 heads?
kukerdan
Dec 6, 2011 01:31 PM
