This is really weird!! Need advice
Old Aug 14, 2002 | 01:12 AM
wh0di's Avatar
Ok ... i just added the following to my 305:
lt4 cam, vortec heads, powerplus intake, holley 670 with stock inj. pod, bottom end rebuild.
Here's the deal with it. I was setting the timing, and i started out at putting in about 4 degrees advanced. Well it would backfire through the intake at 4, and didnt seem to have a very tight throttle response. Looking back I realized that I was probably running lean on acceleration. So I kept cranking up the timing. Right now its pretty advanced, way off the timing scale thing. And it actually runs 1/2 decent, and doesnt give any codes, and my scanner isnt showing any knock (might not be the real case though). 1st gear will pull like *** is yanking it on a string, then 2nd gear seems to bog. The more load on the engine the more it bogs.
I talked to my brother the other day and he said adding that much timing was just like a bandaid to mask the leaning problem.
Do you guys have ANY tips for me? I have a hypertech chip in the attic, does that add more accel enrichment? Can I adjust TPS to add more fuel? Im afraid that im gunna burn a hole in the piston or something if i keep driving it like this. I dont have much money left, so I cant really start burning my own chips.
ALSO, on a side note, I have a new cooling fan switch, can I put in on the intake manifold instead of the head if i just splice a little wire in? THANKS
Old Aug 14, 2002 | 06:27 AM
Slade1's Avatar
Did you remember to unplug the tan wire before messing with timing???
Old Aug 14, 2002 | 11:36 AM
wh0di's Avatar
yes
Old Aug 14, 2002 | 12:55 PM
JR305's Avatar
Are you running the stock 305 injectors and at what PSI?
With mine I needed around 9* of advance to get it to have a resonable idle. DM91RS is running the same heads and cam on his LO3 you might try to PM him.
Old Aug 14, 2002 | 03:21 PM
wh0di's Avatar
Im running stock injectors with the regulator maxed out
Old Aug 14, 2002 | 03:46 PM
racereddy20's Avatar
could you be 180* out? Shouldnt need that much timing. Everytime that my dissy has come out and gone back in it hasnt given me problems. Last time I pulled it out and stabbed it in it was only 2* off. Started fine and didnt backfire or anything. BTW when I started her up she was running 2*ATDC w/ no backfires or problems. Right now shes running at 12* BTDC w/ 160 thermostat in +100* weather with no problems or overheating. Something in your timing has to be off. Did you install the cam straight up? Check all your basics first
Old Aug 14, 2002 | 05:38 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
those stock injectors are probaby nowhere near enough. On my stock 350 i ran those 45 pph with the regualtor turned all the way up and it ran lean enough to instantly vaporize the paint on my headers and make them glow a nice incondesent cherry red in a matter of about a minute. Your engine definatly needs more gas than mine does with all those mods.
Needless to say i promptly went out and got the 55pph ones. Not the best but they keep the blms in reason and it doesnt run lean.
Old Aug 14, 2002 | 08:52 PM
wh0di's Avatar
I ran with the Holley injectors (i dunno what #) but they fouled the plugs and generally ran crappy. They were the old style injectors with the black caps.
Where can i get injectors for TBI anyways?
Old Aug 14, 2002 | 09:32 PM
RSCamaroGuy92's Avatar
Car: 92 Camaro RS
Engine: 355 94 p/u motor
Transmission: 700R4 With TCI kit
I think the local boe-yard might have what you need.
Get some 350 injectors off of a wrecked full size pickup between 87-95. Just make sure the engine is indeed a 350. That should be plenty along with a chip to tell the ecm to give you that extra fuel.
A fuel pressure regulator might also help after this mod.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
