350 Truck Manifold
Old Aug 14, 2002 | 09:10 PM
89fastlookinRS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
350 Truck Manifold
I'm thinking about going a cheaper way than the Edelbrock tbi manifold. I've heard that the 350 truck tbi manifold flows the best out of the stock chevy tbi manifolds. So if I did a home port and polish job on it would I get the same flow as the edelbrock? Or if I had it professionally done, how bout then?
I am doing a LT1 cam swap along with a tbi manifold, it was going to be the edelbrock but I've been hearing it doesn't really feel all that much better. Just at high rpms.
This would save me at least 125 dollars by doing it this way. If it will flow as well.
Old Aug 14, 2002 | 09:29 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i would get a carb one with an adapter. i wouldnt put another stock intake on my car
Old Aug 14, 2002 | 09:31 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
when it comes to suspension. If you can get the right materials and you have the right tools. You can make parts that are as good if not better then store bought products. But when it comes to stuff for the motor. Like something like the manifold. Thats something I would rather buy instead of try to customize.
Old Aug 14, 2002 | 10:53 PM
JPrevost's Avatar
Car: 91 Red Sled
I agree and don't at the same time.
I wouldn't try and make my own manifold but if the intake was going on a set of swirlport heads you can bet I would just hand port a stock intake manifold. If the heads were better I'd opt for aftermarket.
I'd rather design my own custom sheet metal intake manifold .
Old Aug 15, 2002 | 10:08 PM
Car: 89 Camaro RS
Engine: 305 TBI
So do you think the 350 tbi truck manifold, ported, would flow as well? Or better maybe?
Old Aug 16, 2002 | 07:52 AM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Guys, I don't really think the truck L05 got a different intake manifold than my L05, or your L03, for that matter. Might as well port your own.
Someone correct me if I'm wrong though...
Jake_92RS
Jan 28, 2020 10:37 PM
Eric-86sc
Aug 24, 2015 09:01 PM
theshackle
Aug 22, 2015 06:52 PM
st.evel07
Aug 13, 2015 06:15 PM
